Gas smell? (maybe noobie question)
HEy guys, opened my hood the other day and all I smelled was gas inside the hood! Smells terrible any ideas or does everyone have this?
A couple of things.
1. Possible overfill
2. Cracked hoses
3. Loose Clamps
On all four of my 993's I've had the same problem. Usually just tightening down the clamps on the hoses did the trick. In one case a replaced cracked hose was the only remedy.
Be sure to vent out well before doing anything, that battery is too close for comfort!
2. Cracked hoses
3. Loose Clamps
Well timed. I have the same issue. Really strong smell in the trunk.
Have a look at this recent thread, it may help. https://rennlist.com/forums/993-foru...unk-fixed.html
Well timed as I too have the same issue. I replaced the gas cap rubber seal and now the smell has come back.
So using the link Toto111 posted I will be doing the same next weekend!
Well I did the DIY for the clamp check...no real smoking gun there, and still have a slight odour after a few days of sitting in the garage. Not as bad but still there.
Not sure where to go from here...
Jim
Jim
I've done the same and still have the odor. Went through every clamp and hose. It could be the filler neck, not sure.
Maybe its best you guys replace the expansion tank and its hoses? The OP in the link suggested some people did that with great success.
I'm tackling mine in t-minus 5 minutes! LOL
Ok guys, I fixed it about 10 hours ago and now it smells like nothing! I guess that really worked! There is still a little hint of gas smell but it isnt nasty like before!
Ditto! Did mine this morning and now at 8:16pm there's no smell at all.
