993 Forum 1995-1998
Big power 993 engines
Old 12-15-2020, 02:32 PM
  #91
goofballdeluxe
goofballdeluxe's Avatar
"Power" and "Porsche" are two words that never are cheap when used together, regardless of the application
Old 12-15-2020, 11:43 PM
  #92
chsu74
chsu74's Avatar
The old adage.
Power
Reliability
Pick any two
Old 12-16-2020, 05:05 AM
  #93
Holger3.2
Holger3.2's Avatar
Just got a 4.0L build by Christian Treiber.
Stock intakes and remapped Motronic only.
297HP (301PS) at the wheel with 344NM.
more info starts here: https://rennlist.com/forums/993-forum/1152461-tracktool-upgrade-sunroof-and-rain-gutter-delete-and-others-4.html#post16840434
notabot (12-17-2020)
Old 12-16-2020, 06:17 AM
  #94
Madturk
Madturk's Avatar
That one is amazing. Good work
Old 12-17-2020, 11:47 AM
  #95
erikerik
erikerik's Avatar
Holger3.2. Thanks for sharing. Healthy numbers!
Old 10-08-2021, 10:53 PM
  #96
Seahunt73
Seahunt73's Avatar
I got my engine here. https://www.freisinger-motorsport.de
Old 10-09-2021, 03:07 PM
  #97
MarinS4
MarinS4's Avatar
That's a happy engine! Just looking at the shape of the torque curve tells me all I need to know. The cams are well matched to that combination! Enjoy!
Old 07-19-2022, 02:49 AM
  #98
ptuomov
ptuomov's Avatar
Default Knock sensors
Which of these aftermarket ECU solutions can
automatically regard ignition based on the knock sensor output?
Old 07-19-2022, 07:50 AM
  #99
Holger3.2
Holger3.2's Avatar
If you mean ignition retard
EMU Classic
KNOCK SENSING
Channels 2
Resonant frequency range 1-20kHz, 3rd[size=13px] [/size][size=13px]order AAF
Sampling: Ignition event driven,
knock window Actions: Ignition retard, fuel enrichment, dashboard indication[/size]
Old 07-19-2022, 10:50 AM
  #100
Kein_Ersatz
Kein_Ersatz's Avatar
In addition to wideband lambda sensors retarding timing?
Can't see using stock 993 knock sensors for tuning, just as a failsafe.
Old 07-19-2022, 02:14 PM
  #101
Holger3.2
Holger3.2's Avatar
Just a little update on my engine development.
After installing ITBs, another upgrade on the cams and the instalation of a EMU ECU.
Our dyno had a print issue, therefore here the dyno of the sister engine in Germany.
This time power on the crank.
Old 07-19-2022, 02:26 PM
  #102
nothingbutgt3
nothingbutgt3's Avatar
Holy Canoly!
​​​​​​These numbers are nuts! 😍
4.0 with such a config. must be a very expensive application, but it should also provide so very much satisfaction!
Rev limiter set at 8000 rpm?
Old 07-19-2022, 02:41 PM
  #103
Holger3.2
Holger3.2's Avatar
Jepp ...
Old 07-19-2022, 03:42 PM
  #104
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
indeed big numbers for a 2 valve engine - Do you know which correction factor was used for this data?
Old 07-19-2022, 08:29 PM
  #105
chsu74
chsu74's Avatar
9K redline. 4 valve. Robert does some amazing stuff
View this post on Instagram
The following 2 users liked this post by chsu74:
LimeyBoy (07-20-2022), Tyler85 (07-21-2022)
Quick Reply: Big power 993 engines
