993 Forum 1995-1998
ABS & Brake Light On!
Old 05-07-2012 | 01:52 PM
kms0521's Avatar
kms0521
Default ABS & Brake Light On!
Had some previous discussion on this. ABS light on permanently. Brake light intermittent. While fixing another electrical problem, I had all speed sensors cleaned and brake sensors (wire) checked. Diagnostic faults front left speed sensor - signal implausible (code 21 or 25, can't remember). Also cleaned the two relays in the front just above the spare tire.
Looks like I'll need to replace the speed sensor - any suggestions on a good supplier, and do you recommend an aftermarket sensor or should I stick with OEM?
The question I have, which seems to have been implied with some other posts, is can a faulty speed sensor also cause the brake light to illuminate intermittently? I thought the speed sensor had nothing to do with the brake light.
Thanks for your assistance.
Kurt
Old 05-07-2012 | 02:23 PM
Silvertarga's Avatar
Silvertarga
I had same problem (albeit on my 964) Turns out the wiring from the car to the connector block for the speed sensor and brake pad indicator was bad..
Old 05-07-2012 | 03:18 PM
kms0521's Avatar
kms0521
Thanks, Silvertarga. I'll check that out as well.
Kurt
Old 05-07-2012 | 04:59 PM
KMASS993's Avatar
KMASS993
I had the issue with the abs light before I switched my brake sensor wires out. As the pp said, check these.
Old 01-13-2013 | 07:05 PM
HiWind's Avatar
HiWind
is there a way to test the wires? just use continuity? from sensor to ...?
Old 01-13-2013 | 10:51 PM
Stealth 993's Avatar
Stealth 993
There is a resistance test for the sensor, you might want to check it vs. the other ones. Or swap it over to the other side and see if the problem follows.
I would go OEM on the sensor, they are not expensive.
Old 01-14-2013 | 12:54 AM
HiWind's Avatar
HiWind
Thanks Stealth
Old 01-14-2013 | 04:40 PM
pp000830's Avatar
pp000830
Check the relays in the trunk. Also I had this issue until I forced the ABS to go active through a hard stop. This settled the issue and I never saw it again, go figure?
Quick Reply: ABS & Brake Light On!
