Another wheel questions
Does anybody know if these rims would fit a 993 NB?
Front Wheel: Part #: 997-362-136-00 Size: 8Jx 18
Front Tire Size: 235/40ZRx18
Rear Wheel: Part #: 997-362-140-01 Size: 10Jx 18
Rear Tire Size : 265/35ZRx18
These are off a 2005 997 but owner does not know the offsets. Can anybody tell by the part number?
18 x 8 ET 57
18 x 10 ET 58
These are the exact specs I had on my Carrera III wheels originally fitted on 997s. If those numbers are correct, you will have no problem at all even if you're lowered. GL.
18 x 10 ET 58
I had 225/40 but 235/40 will not be an issue at all. There's plenty of room for extra meat at the front. Let me know if you need pics.
Thanks. Just to confirm my understanding of offsets..an offset of ET57 will mean the wheel will be a little closer (8mm) to the wheel well vs an ET65. So this difference is negligible and would have very little impact on the handling. Is this correct?
Assuming both rear wheels are 10". ET 58 will stick out towards the outer lip an additional 7mm compared to an ET65 wheel. The smaller the ET number, the more outward it extends. 10" rim for a widebody would have ET40, for example.
