993 Forum 1995-1998
Removing Speedo unit from dash
Old Apr 19, 2012 | 08:47 PM
breeves_02's Avatar
breeves_02
Default Removing Speedo unit from dash
Anyone have tips on removing the speedo from the dash of a 993? I've read that it can be removed by prying under the outside trim ring, but I don't see how this can be done without damaging the dash or speedo trim ring.
Thanks in advance for the help!
Old Apr 19, 2012 | 08:56 PM
Allen's Avatar
Allen
It's been a while since I took mine out...but I know I removed one of the adjacent gauges, reached in through that opening, and pushed the speedo out from the rear. I think it was the clock...yeah...it was. I was able to get a much better grip on the clock than the speedo...so it came fairly easy.
Magdaddy's Avatar
Magdaddy
all the gauges are simply pressed into place, that rubber ring simply acts as a gasket. Some can be much harder than ohers to remove. Try different gauges, see if any will rotate. Gently pull toward you as you rotate, once one is out...just reach your hand/fingers in and help push out the next.
Good luck
Old Apr 19, 2012 | 08:59 PM
breeves_02's Avatar
breeves_02
Thanks guys. I'll see if the adjacent gauges might be looser. I appreciate the help!
