993 Forum 1995-1998
Trickle Chargers
Old Apr 8, 2012 | 11:18 AM
Dryfly57's Avatar
Dryfly57
Default Trickle Chargers
Can anybody recommend a trickle charger that they are currently using?
Thanks for your input.
Thomas
Old Apr 9, 2012 | 04:04 PM
jfintexas's Avatar
jfintexas
I use the 95504490054, Porsche Dual-Mode Battery Charger. Got it at Suncoast for $109. Works great and can be used for motorcycle as well.
Old Apr 9, 2012 | 04:22 PM
911SLOW's Avatar
911SLOW
Admin
Hi Thomas and welcome to Rennlist, I will move your thread to the 993 forum.
This help forum is for site function issues etc.
Old Apr 9, 2012 | 04:31 PM
boman993's Avatar
boman993
I use a similar unit to the Porsche/CTEK models. I bet it's the same manufacturer;
just a different supplier label on the charger itself. Works great, however, I do not
trust the cigarette lighter plug in. Not sure if it didn't create a proper connection
once, but upon returning from a 2 week vacation the battery was on its last
legs..Not dead, but needed a charge to turn the car over. From then on, I just
attach it directly to the battery terminals, and pinch the wire with the trunk lid.
Old Apr 9, 2012 | 04:34 PM
IXLR8's Avatar
IXLR8
I use a CTEK 3300 for the Porsche. Only so much can be expected from battery chargers in that price range.
If you want to spend a bit more, you can get a Xantrex Truecharge 2, the 10A model, that can handle all types of lead acid batteries. I've seen them for about $150.
Old Apr 9, 2012 | 04:48 PM
WBYonder's Avatar
WBYonder
CTEK 3300; works fine, no problems so far. Comes with clips and bolt-on pigtails. i got mine for about $60 from Amazon.
Old Apr 9, 2012 | 05:03 PM
Gt3 Racer RS's Avatar
Gt3 Racer RS
+1 and lovin it!
Old Apr 9, 2012 | 05:06 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Currently have five Battery Tender Plus's tending both conventional as well as OPTIMA and ODYSSEY batteries. They've served me well and at around $50 a unit, they've saved me far more with extended battery life and reliable starts. One thing tho, they won't save a battery from having a bad cell.
Old Apr 9, 2012 | 05:09 PM
silverporsche993's Avatar
silverporsche993
walmart -- used it for 8 years. cheap too
Old Apr 9, 2012 | 05:12 PM
KaiB's Avatar
KaiB
CTEK
Old Apr 9, 2012 | 05:21 PM
lopro's Avatar
lopro
ctek3300 or battery tender work great
hal m's Avatar
hal m
Battery Tender Plus
Old Apr 9, 2012 | 05:22 PM
tbil's Avatar
tbil
Deltran Battery Tender Jr. Less than $25 on Amazon, working great for years. Came with convenient connect that stays on battery plus the usual clips.
Old Apr 9, 2012 | 05:23 PM
993Maineiac's Avatar
993Maineiac
I've been using the first generation Porsche unit continuously for about seven years with no problems at all. Plug and play- it doesn't get any simpler.
Old Apr 9, 2012 | 06:46 PM
inkatouring's Avatar
inkatouring
From: nowhere, but at least I'm getting there fast!
I used the Deltran Battery Tender Jr. and have two that I don't need anymore. Email me at joshuaweinstein at ymail.com if you're interested in one of them.
