Transmission Experts Stop In....
Seared
I'm not sure what the adjuster does but am interested to hear what the experts say. I have the FD Golden Rod and short shift kit in mine and still had shifting issues. I've changed to Redline NS oil and that made a big difference but it turned out that the shift tube bearing sleeves were stuffed so important to check these. There's two and its basically a metal ring in a plastic/rubber piece and the plastic rubber bit on mine had torn allowing the shifter to "move".
Here's a link to the part mentioned http://www.vertexauto.com/UserData/I...rge/119577.jpg
If anyone was doing the Golden Rod I would advise them to replace these at the same time just for piece of mind.
Noodle Jr.
Seared
Noodle Jr.
Noodle Jr.
So we finally got around to this. A little turn actually loosened up the shift travel a little bit and it is not as stiff. Definitely better but I am still not completely happy with it compared to others I have tried.
I'm still hoping this stays on pg 1 and somebody knowledgeable answers the question. I don't mind experimenting, and will, but before I do want some help to know what's being messed with.
If you go to this URL http://www.porsche.com/all/media/pdf...SA_KATALOG.pdf and navigate > Main Group 3 "Transmission" > Section 302 "Replacement transmission case etc." > Illustration #302-05 where the adjuster (parts 29 to 35) is illustrated.
It appears to be a simple friction piston operated through a spring against the shifter shaft to change the force required to move the shaft.
