quick help on fan housing
Kevin, first you have to pull the fan blade. The center bearing likes to get seized up. Two methods, Wheel puller in the center and some pb blaster. It will come slowly. Another technique that works is to remove the bolts on the center hub and go buy some longer ones. You can run them in until they bottom out, then add .5 turn per bolt working your way around the hub. The fan blade will slowly pull away. Don't rush this method and add Pb blaster in to the shaft repeatedly. Once the blade is off you will be able to access the through bolts that hold the alternator into the housing. This will be stubborn too and usually needs some gentle tapping and lubricant. Unless the bearing feels really good, replace it because you put a lot of stress on it when it is seized up.
Kevin, it all depends on how long it has been on the car. The alternator shaft gets pretty rusty, pitted. The bolt method works well if your patient. The fan blade will creak a bit (like removing a wheel bearing on a press), but as you lube the cleaner surface it starts to break free.
I am going to hopefully refinish the alternator housing & fan and replace the alternator itself. Additionally I will be installing a Clewett engineering kit.
Yeah - agree with Bob on how to remove the fan etc - have done it before and for something that looks so simple it's really a pita
Just watch if you paint the fan - the tolerances are very tight and you may get rubbing
Seared
Answer shortly.
Andreas
In theory yes, but the alternator usually is stuck in the housing. A bit more safe and the shroud provides a handle to work with the blade. Removing the alternator from the housing usually requires a tap or two from a soft mallet and I prefer to have the fan blade out of the way. Even if you remove the entire assembly you still have the task of pulling the fan blade from the alternator.
