How easily are they removed? Will the paint/ clearcoat be noticeably different?
I used dental floss to break the bond and then a razor knife to apply pressure from underneath until the adhesive backing released. I pulled mine off yesterday to clean area and maybe leave off, but I have some hardened adhesive on there that I haven't been able to remove.
I just finished de-badging and here are my "lessons learned":
You will need:
A paint friendly solvent to remove the glue residue
A polish to remove the ghost image. I used a machine but it could probably be done by hand but I expect that would take some effort
The Process I used:
The badge came off quite easily. I did not even need floss but was able to lift it off with my fingers. I did use a credit card as a plastic pry bar to gently lift it up
It left quite a bit of hard, dry adhesive behind
The adhesive was fairly tough stuff but I was able to remove it with "Tarminator" (a spray made by Stoner). It took a number of applications and a bit of gentle scrapping, again with a plastic credit card, to get all of the adhesive off. This took the most time
Even after all the adhesive was gone, there was still a ghost image on the paint
I polished off the ghost with a Dual Action polisher and a foam pad. A two step method using Meguiars D300 (white foam pad) as stage one and followed by a final polish with Menzenra PO85rd (black foam pad)
I removed mine about 18 months ago. The Carrera script was easy to remove, but the adhesive was a pain. After several washings and waxings you can only see the goast image is only visible from certain angles.
