Clewett Engineering - Serpentine Belt Kit
I think the biggest issue with the setup will be the charging. I live in Boston and drive my car in the summer. That means both a/c, traffic and some city driving. I'll do some research on the RS pulley and see what bad experiences people have had from that standpoint. I'll report back if I move forward as I am sure others are interested in the setup. Thanks all!
The only way for the serpentine mod to achieve OE charging rates is to overdrive OE fan speed ( by pulley diameter change from OE) .... perhaps that is the case .... but I did not read any promo claiming "improved engine cooling", so unless otherwise advised, I'd think that OE fan speed was maintained.
One thought is that if one were to be interested in doing the factory lightened RS crank pulley + the factory RS fan pulley anyway, the cost of the Clewett kit is about the same and perhaps a nicer bit.
Hmmm...I'm on my 3rd alternator belt just trying to get one the right size (classic little red riding hood story...first one from Pelican was too small, the second one from NAPA stretched until I ran out of shims to remove, and I just installed a 3rd from O'Reilly a few minutes ago that *seems* just right; despite being the same brand and part number as the one from NAPA. If I had $600 to burn this would be very much a welcome addition, I saw it a while back but didn't notice they had an option to retain AC. Having to almost completely undo the compressor to service something that seems to be somewhat failure prone is incredibly stupid. I can only imagine trying to do this roadside!
The first one was! There was no way it was going to work, I could barely get it over the alternator shaft, let alone positioned properly on the pulley. The length was right but I wonder if it was cut just a bit wide. If #3 doesn't work out for me I'll try another Porsche belt, but so far so good..
Noodle Jr.
Edit: Just discovered what I was seeing on Pelican, the Rothsport pulley half, is an optional piece. Looks like I should probably do this mod while I'm replacing the alternator. Yeah, I should probably do that.
