993 Forum 1995-1998
Clutch & Flywheel
Old 03-03-2012, 02:59 AM
inkatouring
inkatouring's Avatar
Location: nowhere, but at least I'm getting there fast!
In terms of hills, I have a LWF here in San Francisco and I use the car as a daily driver. To my experience, once you get used to the LWF, hills aren't really an issue. And we got hills here...
Old 03-03-2012, 03:29 AM
mongrelcat
mongrelcat's Avatar
Originally Posted by TravisB
Hmm..maybe the clutch fork bearings? :-/ I guess everything in there is new on my car too..
I think it's complete --
Code:
item				qty	p/n
sachs rs pressure plate		1	964-116-028-03
sachs rs clutch disk		1	996-116-015-32
sachs rs release bearing	1	944-116-080-01
mwf				1	--
ring gear			1	964-114-143-31
pilot bearing			1	931-102-111-00
rs guidetube			1	950-116-813-30
flywheel bolts			9	928-102-151-01
pressure plate bolts		9	900-067-103-01
release arm bearings		2	950-116-715-01
needle bearings			1	999-201-339-00
needle bearings			1	999-201-365-00
bearing seals			2	999-113-418-40
clutch fork			1	997-116-086-90
clutch shaft			1	950-116-710-04
Old 03-03-2012, 11:18 AM
TravisB
TravisB's Avatar
That's odd...you replaced more stuff than I did! I re-used my clutch fork and shaft (although they looked fine). Although..did you replace either or both of the master and slave cylinders?
Old 03-03-2012, 12:40 PM
77'3.6vram
77'3.6vram's Avatar
Default I have a 96' and...
[QUOTE=mongrelcat;9328984]He has a '98, no issues with stalling... (put the extra $500 towards something else.)
I have the MWF, and I still find it challenging to work sometimes.
After speaking with Steve Weiner I bought the Andial MWF because he said that it is the ONLY way to assure that the car will not stall when coming to a stop light. If you "find it challenging" to operate a 993 with a MWF you need to learn how to drive a manual transmission. The LWF I have on my turbo is another story altogether. It is like an on off switch and does take some extra concentration to engage smoothly.
Old 03-03-2012, 11:23 PM
G$ 993
G$ 993's Avatar
inkatouring, could you give me your impression on noise at idle. Thanks!
Old 03-04-2012, 12:43 AM
jennetd
jennetd's Avatar
G$ 993, If your interested in a LWF setup I selling mine here's what I have:
Light weight flywheel Bremkek 96411401299 no chatter or heat mark looks as new
Clutch disk Sachs 1861568331 6 spring center still has number on friction disk
Clutch cover from GT3/GT2 or TT old number 3083042001 superseded to 3082213136 verified parts number from Sachs tech dept
same used for the 996 GT2/Turbo/GT3. still has groves from when new
RS guide tube 95011681330(Porsche) No picture but will be included
RS throw out bearing 94411608001 (Porsche)
these parts were in my car for less that 1000 miles
I think these parts combined weigh about 1/2 of the dual mass set up
New cost around 1,600
Used, looking for 850.00 will include shipping
I also have 2 dual mass fly wheels and Pressure Plates an throwout bearings too if that the direction you want to go.
let me know if interested because I do have the LWF/clutch for sale on another board
Old 03-04-2012, 12:45 AM
jennetd
jennetd's Avatar
I'm located in Seattle
Old 03-04-2012, 12:52 AM
Falcondrivr
Falcondrivr's Avatar
Please join as a member to sell stuff.
Also: that is a screaming deal. All one needs is the shorter flywheel bolts and it's a complete package.
GLWS!
Old 03-04-2012, 01:09 AM
TravisB
TravisB's Avatar
Is there anyone in the Portland area with an LWF whose car you could just check out? What's nothing to one pair of ears is obnoxious to another. Maybe Steve can refer you to someone?
As far as noise, my take on the idle rattle is it's negligible compared to the low RPM acceleration sound..probably wouldn't notice it unless you were looking for it, and with the radio at any volume I can't hear it. The low RPM accel noise is considerable though, that yellow-orange thing was in the sky today so I was driving around with the windows down, and was a little shocked at how loud it was outside the car. Granted it's a pretty tame exhaust system noise-wise, but the Dach X and motor sound mufflers were no match for it..
Old 03-04-2012, 02:04 AM
jennetd
jennetd's Avatar
I have the short bolts if you want but its not recommended (stretch bolts). the bolts cost about 4.00 each 9 needed and while your there may as well order the shift fork bearings and bushings cost about 5.00 for the bearings each
Old 03-04-2012, 06:33 AM
mongrelcat
mongrelcat's Avatar
I replaced the fork/shaft as they had 130k miles... Yes, the master/slave and slave hose were replaced, and the kinematic lever was updated.
Old 03-04-2012, 11:48 AM
TravisB
TravisB's Avatar
Well, I got nothin' then. Maybe it's a Grand Prix White thing..
Old 03-04-2012, 12:06 PM
os993
os993's Avatar
I have a '95 with lwf. I've had it for ten years without any stalling or issues. I don't see the point of upgrading and going mwf.
Old 03-04-2012, 05:37 PM
levtron
levtron's Avatar
jennetd, why did you remove it after only 1000 miles? I need to do my clutch and this looks like a good deal on what I was planning on anyway getting
G$993, If your not interested, I maybe...
Old 03-05-2012, 01:34 AM
G$ 993
G$ 993's Avatar
Thanks for the continued feedback crew. I will talk to steve to see if he can hook me up with someone with the set up. If not, perhaps I need to make a trip north to one of your Seattle drives for a demonstration!
jennetd, PM sent.
Quick Reply: Clutch & Flywheel
