T-Lock keyless entry by Tore=awesome/easy DIY
#47
Of course!
You'll be able to get a T-Light kit mounted before Christmas, at $110.00, shipping included. There's also a multiple item discount, $10 for two products, and $20 for three. Orders are welcome on my web site.
Discounts will be refunded immediately after purchase.
Cheers and thanks in advance,
Tore
Tore
#49
Tore, are you still offering the T Light for $110?
#50
thanks Tore, just purchased the light. So do you credit back the $20 after purchase? Your T Lock is great, can't wait to get the lights. Scott
#54
Tore this T-lock is just TOO COOL, I love it.
I'm not concerned that the range isn't great, just not having to use the key is SO nice.
T-light order coming next month
#55
Great news DB_NC_95C2! I look forward to hear from you again.
I've not seen many problems with the range of the remotes before, it should be in the range of 10-25m, maybe even more. This highly depends on the T-Lock main unit antenna position. If it's stripped down to metal surfaces you might experience some problems. Could this be the case?
Cheers,
Tore
Cheers,
Tore
#56
I get about 8 meters maximum range, I need to slide the seat forward and see how the antenna looks. I didn't do it myself, didn't have the time. Had a tech at local Porsche store put it in.
Is there a recommendation for the antenna wire ? (i.e. flat, facing forward, backwards, straight up (as much as possible), etc ?
#57
8 meters is a little bit on the low side yes. The ideal antenna placement is straigh up at the middle of the roof. :-) Reality is something else, I recommend to not strip it hard down to metal surfaces, but have it to hang a little loose, preferably in free air. This is often difficult or impossible, especially under the seat, so I often leave it hanging a little loose under there.
Cheers,
Tore
Cheers,
Tore
#58
I installed my T-Lock today and when I reconnected my battery the Porsche lock unit started buzzing. It goes away though once I start my car. I have triple checked every wire connection and tested everything per the instructions... Any insight on this?
#60
bosoxfan, your post indicate that the T-Lock is not connected properly. I have extensive insight in this, please disconnect the T-Lock and contact me on email or PM.
Cheers,
Tore
Cheers,
Tore
