993 Forum 1995-1998
Modified Intakes Manifolds
Old 02-25-2012, 08:25 AM
James Hunt
James Hunt's Avatar
Default Modified Intakes Manifolds
Found this on the web. Its a 1984 SC with a very nice intake manifold (note the reversed cone filter!)Is this something you can buy somewhere in a different guise (I'm guessing not) or are things such as these one off fabrications? Any info would be appreciated as I'm looking into this and might be doing some serious power upgrades sometime in the near future.
James
:thumb:
Old 02-25-2012, 10:26 AM
AOW162435
Seared
AOW162435's Avatar
That thing looks like it would suck in local cats & dogs...
Andreas
Old 02-25-2012, 10:41 AM
Bill Verburg
Bill Verburg's Avatar
James
:thumb:
That's a mechanically injected motor, very old school and not something you would want on a 993
one way to go is what they did on the 993Cups, no MAF sensor, uses MAP to control mixture, but has poor idle control
A much better approach is individual throttle bodies
even better is ITB's w/ a resonance chamber plenum
Old 02-25-2012, 11:35 AM
race911
race911's Avatar
High butterfly MFI! I can't imagine why they'd have that setup, absent OE requirement for show or vintage rules. It's basically the stock air filter for everything from Day One to the end of the 911/83 (aka RS) engine production. While we were in the dinosaur era back then re: dynos, pretty much everyone put the dual K&N filter setup on everything but the Ts. Truly a difference? Who knows!
What are the "serious power upgrades", and what exactly do you plan on ending up with if you spend half-to-as much as the car is worth to do it properly?
Old 02-25-2012, 02:15 PM
Bill Verburg
Andreas
It's missing the outer screen, #9
Old 02-25-2012, 02:30 PM
Bill Verburg
yes, but not the usual Bosch MFI, Kugelfisher was used on that one
Old 02-25-2012, 03:01 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
James
:thumb:
That's a 911SC/RS,...one of about 22 cars. Those cars have MANY unique parts that were one-offs. Big, big money for those parts as the cars are worth $350K or more.
JMHO, but there are many good performance options for you that are less expensive, depending on what you do with your car as well as your budget.
Old 02-25-2012, 11:23 PM
race911
race911's Avatar
Absolutely. Mainly I was referring to the basic setup of the air filter on any MFI 911, as delivered.
Did that one get my attention when I first got into these things! Never seen one in person. None were used here competitively, were they?
Old 02-26-2012, 12:09 AM
Nope, ROW only due to very limited production and races not run in North America.
We had one here for awhile and I got a chance to drive it when its was all done. Quite the ride,....
Old 02-26-2012, 02:27 AM
CalvinC4S
CalvinC4S's Avatar
This one has the plenums and ITB's.. The plenum in this case was necessary as it was forced induction.
Digi cams where not that great in the 90's.
Old 02-26-2012, 04:21 AM
911PERVY
911PERVY's Avatar
I think you now know what engine its from, (cant beat this place for knowledge!) I also think Porsche have a pretty good idea of how to make intakes, they do a little testing and tend to come up with the best results.
On a n/a 993 get Wayne to remap it. If you want more power after this, sell the car and buy a turbo
Old 02-26-2012, 08:22 AM
James Hunt
James Hunt's Avatar
Bill, thats some good info and pics to boot! Thanks! Keen on the ITG individual throttle bodies. What other modifications are needed to run a setup like that, and where is good to source a kit from? Guessing those TB's are a couple of grands worth easy. I always do things properly, with NOTHING skipped or done cheaply. At the moment I'm running a full decat with a BMC cone filter.
911PERVY, I've already had a live map and produced good results after a decat. Your other point was a bit , well, pointless wasn't it! Thats like saying "if you want a bigger house after you build a shed, sell it and buy a castle". Thanks for that very in-depth and technical feedback. Put the kettle on.....
JAMES
Old 02-26-2012, 10:37 AM
911PERVY
911PERVY's Avatar
Maybe what I should have said was bang for buck dont bother doing anything, unless you have £20K to spend on something that wont be worth anywhere near that and wont improve performance by more than about 10%. The remap and exhaust are the best things you can do on your car, now it becomes crazy expensive for very little. The cone filter has probably reduced power TBH
And yes, if you want a bigger house you can build an extension or move into a bigger house. A bigger house is the easier step!
Old 02-26-2012, 10:45 AM
juankimalo
juankimalo's Avatar
This is the Singer 911 engine made by Cosworth
Is the intake manifold from a GT3 RS?
Could you describe the parts used in this engine please?
3.8 conversions have been made more than 20 years, and this is something not new.
My specialist recommends several brands and parts, but I cannot identify them in a single picture
Besides, Singer Vehicle Design used to give the whole info when their engines were built by Colin Belton (9M), but we don't have the Cosworth engine's specs
Do you know it?
Old 02-26-2012, 12:30 PM
Bill Verburg
JAMES
Both Steve Weiner thru Rothsport and Colin Belton at NineMeister have nice ITB kits. You need an aftermarket ECU like Motec, Pectel etc to run the engine and custom tuning. To really take advantage of the ITBs you will need to raise the rev limit and run much lumpier cams, this means a complete crank up redesign and rebuild.
for most of us that don't raise the rev limit stock intakes and RS or SS cams w/ stock internals as long as the valves clear the pistons are more appropriate
Quick Reply: Modified Intakes Manifolds
