Did all 993 come with keyless remote?
Thanks, Tore!
We were discussing putting a diode in series o the wire to the turn signals. Have to check my controller's manual, I think there's only one output to the turn signals, not two separate ones like on your unit (nice touch, actually!).
I agree nile13, if your unit have only one relay output you'll have to use two diodes in order to separate the turn signal circuits. Both diode anodes connect to your +12V relay output, and cathodes to each turn signal circuit. Easy.
Cheers,
Tore
Cheers,
Tore
Thanks again, Tore! I have not done the light output since the click of the door actuator can wake up the dead
But I probably should, just to have it finished.
