How to replace cab roof switch
Hi,
the center console switch on my cab needs to be replaced. I got a new part. Would any of you have the DIY instructions to replace the switch ?
Thanks!
m
Thanks!
m
No DIY instruction as it's fairly easy. The two consoles are a friction fit...just pull up along the edges with your finger tips. Once removed, you will see that the switches are held on to consoles with prongs that you can squeeze from the rear.
