intermittent alt warning light
Last week, first thing in the morning upon startup, the alt light stayed on for 30 seconds or a minute. I got worried and then it went off and I figured the belt was slipping but stopped. Well, this morning same thing, but the light stays on about twice as long...
Thoughts on this?
Thoughts on this?
Do you have a voltmeter? I have one I can plug into my cig. lighter socket. You should be getting around 13.5 v when the engine is running. A dying alternator can REALLY leave you stranded.
Where did you mount the voltmeter? Pics?
As already mentioned, take a battery voltage measurement while the warning light is on.
Mine sits above the switches on the center console and is held to the carpeting with Velcro. I don't like cutting or drilling holes in my car.
I made mine. Whatever you use and however you connect it, make sure it reads the actual battery voltage. If it is connected to the cigarette lighter, take a measurement at the battery and confirm that the voltages are the same. In my case and due to the type of voltmeter I chose to use, I was able to connect it directly to the battery, after all, that is the voltage I want to monitor.
Change out the alternator at a Dealer!
On 4/4/08 Danbury Porsche replaced the alternator and belts. The rebuilt unit was $315.55 plus three hours of labor and the belts. The total bill was $798.94. FYI - The rebuilt one failed on 5/19/08 and the dealer had to do the job a second time plus pay for my towing. It was a blessing that I had this work done at the dealer. They told me that this was not the first time that a Bosch reman had failed within three months of the install.
Last edited by 77'3.6vram; 02-08-2012 at 10:40 AM. Reason: Alt part number is 964-603-156-AX
Hopefully I picked pics of ones that fit 993s' cigarette lighters.
I had the same problem and after checking voltage and seeing low voltage I ordered a new alternator. During the replacement process I found that the nuts were loose on the back of the Alternator and there was nothing wrong with the old Alternator !!!!!!!!!!!! There is another post listing the same problem, I would just check the nuts on The Alternator, It will require taking the old unit out to see the back, If the bolts are loose it is an easy fix if not then order a new alternator and you are already halfway done with everything apart.
Also, anyone knows if this fit the 993 cigarette lighter?
