View Poll Results: What would you roll with on a Black C4S? Amber or Euro Clear turn signals?
Amber
15
30.61%
Euro Clear
34
69.39%
Voters: 49. You may not vote on this poll
Amber or Euro? The Turn signal DIY
I inherited a set of Euro clear turn signal lights from the previous owner. Packed up in a box, still wrapped in that clingy plastic film; basically a BRAND new set. So, I had this idea of asking Rennlist what lamps I should install on the car. The Euro clear? Or the OE amber? But before posting pics to support the poll, I needed to convert the Euro lamps to fit my US bumpers ~ Basically shorten them. Which gave me an opportunity to do my first DIY vid!
After a closer inspection of these brand-spankin' new lights, and a few test fits on the bumper; it was obvious that these are really crappy aftermarket replicas. Even the bulb sockets do not make a full seal when installed. I also noticed that there is a hair-line crack in the lens on the left side!! So, just a side note, if you're going to do this mod, start with a genuine Porsche part that's not broken! I will need to redo the DIY in the future with some proper parts if the vote sways to do clears!! No sweat though, it was still a great run through ~ and a nice way to get my feet wet with a set of lamps I didn't care too much about. Plus, it's going to be interesting to hear what you guys think!
The DIY:
Here is a list of tools you'll need to complete this project:
Euro 993 turn signals
Hacksaw with a new blade
Saw cutting guide (not necessary)
Pencil or Sharpie
Scissors
Painter's masking tape
A tube of silicone sealant
A philips screw driver
Shop towels or a clean rag
Tinsnips ~ just incase you need to trim additional plastic.
With a philips head screw driver, Remove the original lamps from the bumper. Once the screw is out, pull the unit to the front of the car to slide it out. Using masking tape, tape off the whole lens to create a template. I marked it off using a pencil around the lamp, as well as punched a hole where the screw is located. With scissors, I then cut off the excess tape.
Carefully peal off the tape guide you created, and transfer it onto the Euro lamp. Take care with this step, to try to retain the measurements you just made. I found it was easiest to align the screw hole first and then the rest of the light. You should now have a general idea of what you'll be hacking off.
Prepare to cut the lamp fixture. I used a cutting guide, but I don't think this is necessary. As long as*you are able to clamp down the lamp securely, or have someone hold it for you so it doesn't move around. The hacksaw cut through the plastic like butter ~* it was quite effortless. (because they're Chinese knockoffs maybe??..ha).
Clean up the cut to eliminate any plastic saw dust, also ensure none got inside the lamp. Now you can prepare to use silicone to seal the fixture. In my case, I was a bit nervous that a single bead of silicone wasn't going to give me a proper seal. To remedy this, I had some thin, scrap plastic laying around, and so I cut out a small piece to fill the hole.* Once the silicone is in place, using a wet cloth, I wiped away any access that was left behind.
Wait the required time for the silicone to dry (in my case roughly 30 mins), and pull off the template masking tape. Inspect your work, and also test fit on the car!!
Rinse, lather, repeat for the other side!
BOOOOM Done! You now have modified Euro clear signals to install on your Porsche with US bumpers!
So what do you think?? What one should I roll with? Euro clear? or OE Amber?
The DIY:
Pencil or Sharpie
Scissors
The production quality of your videos as stated before is excellent. I have a set of Porsche euro signal lights sitting in a box in the garage, but I'll be taking the bumperettes out of the bumper and filling the holes instead of cutting the lights, as I hate the look of those silly bumperettes. I'd obviously vote for the clears, but a shot of your car from farther back might help some people decide. I look forward to your next video.
Thanks for the positive comments everyone!! I'm having a great time making
these videos..I have so much more to document!
Even though the euro is clearly winning...I think I'm also leaning amber!! Maybe if
there is a way to split the lenses from the housings and paint the chrome gunmetal
or something....I feel like the euro lamps stand out a bit too much on a black
car..
Originally Posted by DFC4S
Amber, great job on the video.
car..
I think the clear would look good if the euro look is completed on both bumpers... Loose the bumperettes on the front - fill the holes and back - install euro rear bumper and install the amber lights)
the term "slippery slope"! Bumperette delete is definitely on my list of things to
do..but probably not until 2013.
Originally Posted by nels415
Nice vid Mr. Art Director, now can you do a engine out and disassemble DIY video?
-nels
-nels
clutch time there will be some engine droppin', disassembly/assembly going on!
