993 Forum 1995-1998
Door compartment
Old 01-30-2012, 09:03 PM
Priceless
Priceless's Avatar
Default Door compartment
I just noticed the plastic is cracked by the screw in the front of my driver side door storage compartment. Any suggestions besides superglue? Thanks.
Old 01-30-2012, 09:11 PM
1pcarnut
1pcarnut's Avatar
This is very common on just about all the 993s. If you do a search, there are several repair options. I made a small plate out of aluminum to reinforce the plastic. Attached it with rivets and contract cement.
Old 01-30-2012, 09:19 PM
Priceless
Priceless's Avatar
Thx...I'll check it out. Would u mind posting a pic of ur fix?
Old 01-30-2012, 09:26 PM
Cincy_Ron
Cincy_Ron's Avatar
Do a search on this forum for "broken door pockets" and you'll see some fixes some have come up with.
Old 01-30-2012, 09:27 PM
ble2011
ble2011's Avatar
I have the same issue. I was going to try fiberglass/resin with a washer embedded. Then sand smooth and repaint.
Old 01-30-2012, 10:48 PM
Cactus
Noodle Jr.
Cactus's Avatar
Same here. In for the best solution!
Old 01-31-2012, 12:41 AM
IXLR8
IXLR8's Avatar
The last time I had my door trim panel off, I took some measurements and had some thin stainless steel sheet cut to make plates that should fit the surface area perfectly (I have yet to install them). I then punched holes in the plates for the screws. The plates will be bonded to the back side of the door panel using JB Weld.
Old 01-31-2012, 01:02 PM
1pcarnut
1pcarnut's Avatar
Exclamation
This is what I'm talking about except I used aluminum stock. My current pockets needs this fixing but haven't gotten to it yet. Did it on my last one a couple years ago. Will see if I can find some pics.
Old 01-31-2012, 01:12 PM
vincer77
vincer77's Avatar
I had some ABS plastic clips that were used in some packaging I received and glued them in place using ABS cement. Real solid now.
Old 01-31-2012, 01:29 PM
Kika
Kika's Avatar
I use 2 part epoxy for a number of things, fixing the door pocket was one of them.
1pcarnut
1pcarnut's Avatar
Here's the thread with a pic of my repair (post #5). Next time I did this I painted the plate black to blend in better. The repair was still holding strong two years later when I sold the car.
https://rennlist.com/forums/993-foru...t-queston.html
Old 01-31-2012, 02:30 PM
Priceless
Priceless's Avatar
That pic looks like a gr8 fix.
Old 01-31-2012, 04:55 PM
1pcarnut
1pcarnut's Avatar
Relatively easy to do and seems to last. There are other solutions but this worked for me. As an FYI, this plastic is PVC based if I recall and when I was patching it I used a very thin plastic cement to glue it as best I could first. It's called IPS Weld-On #3 and described as "clear, water-thin, very fast curing solvent cement". Then did the aluminum reinforcing plate.
I get the glue from TAP plastics, don't know if they are national or not. This glue is fantastic for gluing acrylic based plastics (which is used a fair bit on our cars) because it works on a capillary method. You put just a little on with an eye dropper or syringe, let the glue flow along the break and then press the pieces together. You can literally see the plastic melt and squeeze out of the seam. Takes a couple of hours to really set. One caution, don't let it run down your plastic piece because it will leave a white chalky stain.
Old 01-31-2012, 06:43 PM
Neil Perry
Neil Perry's Avatar
Hi
I made some aluminum strip about 20 mm (1 inch) shaped it to the plastic, drilled a hole to suite the existing hole, painted the outside of the bracket semi gloss black and the used 2 part epoxie to glue it in.
The passenger side had not cracked, but I made a bracket for it as well and attached it, it was easier to make two at the one time and not have any further issues.
If you look in the pocket now it is all but impossible to see this mod, actually it looks like a factory upgrade for a later model door packet.
Thanks,
Old 01-31-2012, 06:50 PM
IXLR8
IXLR8's Avatar
I have to find out if Lexan can be glued to the existing plastic panel.
A thin piece of "black" Lexan would be perfect. Lexan cannot be cracked or torn.
Quick Reply: Door compartment
