993 Targa roof stuck
My 993 Targa glass roof got jammed at the close position, driver side cable is stripped, I removed the wind deflector and the glass roof and both motors but the tracks still stuck, im trying to free the front and rear axles, I can't move the tracks, is there a locking machanisim that locks the tracks. I will replace both cables and whatever parts needed, this is very complicated system, the car is parked waiting for help from a professional. Your input is appreciated.
Ahmad
Ahmad
I contacted a guy at the dealer thru a friend and told that I have to remove the tracks as the timing needs to be reset on the tracks, there should be some lock to free tracks than remove the whole thing to set the timing, I don't know.
Ahmad
Ahmad
MikeJ's website may give you some assistance. He is very good with Targas
http://www.pcarworkshop.com/index.ph...ration_Outline
^^^^A very good source of Targa information
Mike
Mike
Mike,
I believe that I have to remove the whole top to disasimble the tracks and replace the cables, I went thru mike's website but nothing about unlocking the tracks when they stuck.
Ahmad
Ahmad
check them out, ask for Soreen tell him Ali sent you! Rima is between the 2 roundabouts near the Avenues mall
if you are coming from the 4th ring road, instead of taking a right (to go to the avenues parking lot), take a left and you will be on a rising road, once you are at the highest you will notice Rima on your left so you will need to turn around (either U turn or at the next roundabout just 200m away)
good luck! pm me if you need anything mate
Hi Boursachi,
I checked with Sorin at Rima motors but he appologized and said that he tried to rebuild one Targa roof 6 years ago and it was a nightmare and could not do it. I will have to do this job myself but I need some information to remove the tracks without moving the whole top.
The dealer estimated $7,000 to repair it which I understood that they don't want to get involved, they want to change everything including the 3 motors.
By the way what year Targa you own, mine is 1996 and found out there is a recall on the engine wiring harness.
you can call me to discuss, mynumber 66614111
Cheers
Ahmad
Cheers
Ahmad
Ahmad, seriously man I am SO SORRY for not checking those threads more often!
I could swear I subscribed for instant email notification.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I just replied to your other thread, and yes Sorin did tell me about that encounter.
He told me to be careful with my roof the minute he saw my car when I brought it to them.
My car is a 1996 model as well.
I saved your digits and will give you a call ASAP. I am on 99702935.
-Ali
-Ali
