Free play in distributor shaft
I plan to modify the standard 32 x 12 x 10 bearing by opening up the inside diameter to 12.4. Thats one of my next projects.
You may be able to find a used distributor, or if you are lucky, a never-used NOS distributor on eBay. I just picked up a new distributor on eBay for less than the over-priced price of new bearings that one re-builder claims to have.
Alex, Thanks again for the help I sure need it, what started out as a spark plug change has turned into, New plugs, wires, cap & rotors, valve cover gaskets, gas filter, clean top of engine, clean ground points and now a new distributor!!!!
How long do you think my distributor will last in this condition or is this an immediate fix
How much play do you have side to side and up/down? There is a Belleville washer that preloads the bearing, so you shouldn't have any up/down movement. You'd really have to disassemble it and check each bearing individually by feel.
I tend to fix things if they aren't 100%.
If my distributor bearings were gone now and I didn't have my NOS distributor on stand-by as I do, I'd buy a rebuilt distributor and rebuild the old one when bearings come available at a reasonable price...and that might be sooner, than later.
Plan B is to exchange the new bearing inner 12 by the old 12.4 inner ring. The hint ? Hot and cold ....
need is the mother of inventions.
I cannot see how a mounted distributor could have the secondary shaft wobble.
If you want to know why it wobbles left and rights few degrees, it is to replace the manual retard timing beginning of the century cars had on the steering wheel.
With inertia, the faster the rotor spins, there are two small sprung weights underneath the rotor that open and retard the rotor a few degrees.
When the axle is on stop, and you turn the rotor anti clockwise, the rotor will move freely, sprung a mist, but moves a few degrees.
If so, go WOT one for your friends here and no worries.
It'll only cost me the price of a standard bearing...not much.
George, thats like using an old outer race of a tapper bearing that is still stuck in the hub with a new inner race of a tapper bearing that was just bought. It may be a last resort, but its not my style. Besides, if the old bearing is running rough, then chances are both races are done.
One could always turn down the distributor shafts, but I wouldn't want to do that either.
Leave it to Bosch. Now you know why I dislike anything that uses proprietary parts. But they are out of luck; a solution is on the way.
