Last efforts before calling the hook...'95 C2, won't start after engine R&R.
#46
Sorry to hear of the plight. Been there many times, and am really glad I'm not doing engines anymore. How much simpler it was in the old days with a carb/MFI engine and conventional ignition.
Unfortunately, nothing to add that I haven't seen covered.
#47
Can it only be install in one location?
#49
I would still do the 3 tests in the workshop manual to confirm that the DME is getting the information it needs. I'm not certain that what you're seeing proves that it is. Totally simple tests that are worth the 5 minutes.
Are you sure the ISV (idle stabilizer valve) is hooked up properly? Maybe the engine could be starving for air if the ISV weren't operating correctly. But I suspect enough air could still get past it to fire up the engine.
You didn't block off any air inlets with shop towels or duct tape, right?
#51
Juha, I think even with an incorrect plug, the car would at least burp, right? I do not think this is the issue, what do you think?
We talked about the flywheel/crankshaft alignment as well, there is a dowel that Travis confirmed, as well as for the flywheel pulley. That is why I was/am pushing to check each cylinder for correct firing given a timing light. That was in the other thread - there are two parallel technical diagnosis going now!
Travis, how are you feeling these days, and any news?
Cheers,
Mike
Cheers,
Mike
#52
Sounds like I missed a bunch... so you have connected a timing light and confirmed that at least the #1 top plug is firing at the right time consistently....
Have you removed the plug from the head and confirmed that it is actually sparking when the motor is cranked?
While the plug is out and you are cranking the motor you should get a noticeable aroma of fuel... Maybe rent a boroscope to confirm you are getting fuel (piston will be wet after all of this)
I would be bald by now.... sounds very very frustrating...
#53
Yup, that has all been done and much more . Take a look at the other multipage thread:
https://rennlist.com/forums/showthre...referrerid=235
Cheers,
Mike
Cheers,
Mike
#54
When GC96 came by Tuesday he brought the manuals, I don't remember what exactly we did, but we went through the no-start troubleshooting stuff and eliminated everything except a failed DME. I have a hard time believing with spark and fuel that it's bad, but I am running short on new things to check, will probably take a closer look at it next.
And, speak of the devil, he's heading back over this evening with a fuel pressure gauge and an ISV to swap out because...well, why not I guess!
As you can imagine, the caps have been on and off several times..rotors are definitely moving!
Cheers,
Mike
Cheers,
Mike
I think I'll see if Vatozone rents timing lights on my way home today, if they do I will FINALLY check the rest of them.
Not going to lie, morale is starting to slip. 2012 could be getting off to a better start indeed..
There is no cure; only poverty. Embrace the money pit!
Yeah, you're a little late to the party, I think it's about over, but come on in! Thankfully I had the foresight to buzz my head before starting so it's a little harder to pull my hair out. My "project beard" has passed the itchy stage at least, probably starting the homeless look now..
#55
Travis, on the front of the distribut there is a plug, I believe it sends a cyl signal for the dme to figure knock sensing. Not sure if it will run removed or not.
#57
Sorry about the issues. i just watched the video of the car cranking. I have not cranked my car with the DME realy pulled, but yours sounds like the spark pugs are out. Have you checked compression?
#58
Travis,
In lieu of a timing light to check each wire, I recall a clip-on tool I saw at ..Autozone maybe? relatively cheap, like $12 bucks. Flashes a signal when there is a spark.
Edit: found it, $8.00, autozone part #25045
#60
