Aluminum valve covers
Of course, they are at a considerably higher price point than Hargett or others than do not have clips.
Personally, I have not found the routing to be an issue at all. The grommets that the wires go through in the tin hold them very well and it is easy to slide them up a bit to shorten the part that is below (if needed).
No, that was during my Beru ignition cable change last winter.
The first winter I had my 993, I changed my valve cover seals and spark plugs...
The upper valve covers were done from below, so you might wonder why I removed the blower/ducting and air cleaner assembly...I like my engine to be operating-room clean before gaining access to engine internals, so removing those items made it easier to do so.
To the OP, these engines are really very basic once you get to know them.
- I took the complete exhaust system off (to replace gaskets, replace all fasteners and to make sure none were seized)...that would have made it easier to get to a couple of valve cover fasteners
- I removed the left and right engine tin
- I removed the blower and associated ducting
- I removed the air cleaner assembly
Mike, you probably know this but there are a few options for billet aluminum VCs... Eagle Day covers have wire clips, for example.
No biggie though - sounds like you are a billet valve cover fan?
Cheers,
Mike
Yup, know about the clips., and looked at some of the aftermarket ones that can be bolted to the cover. Maybe it goes against my tidyness inclination - the line lengths are designed for some routing, and I found then I shortened the lines after the large grommet in order to have them "supported", I had excess wire on the upper side that looked, well, messy on the topside. Yes, I know it cannot be seen easily, but I know about it.. LOL!
Cheers,
Mike
Cheers,
Mike
A fan of the billet covers? Well, I like the look, yes. And I'm kinda into the mod thing in general
Keeps me out of trouble!
For the clipping problem, I found a 964 part on the Automotion site that are plug wire clips that install under the VC bolts. 6 required for the car, cost about $5.
Much more elegant solution than the wires just dangling there.
I can check the part number when I get home.
i changed lower to get rid of leaking and also helps a lot to heat dissipation. I live in miami where is always hell-hot, so some aditional coolness is highly welcome ... Being 2 big chunck of aluminum, the dissipation from that side should be very high .... also, byebye to gasket failure for a longg time ...
(i love the look too .... hehehehe)
