The Immobilizer Strikes Back!!!!!! HELP!!!!
#31
In one post you've gone from "not possible" to the above, which is essentially "possible but with risks." What will tomorrow bring?
#32
Not really a problem if he buys a Euro fob. The total will be considerably less than what is being quoted, so long as its compatible with the DME.
#35
"In one post you've gone from "not possible" to the above, which is essentially "possible but with risks." What will tomorrow bring? "
O.K. again, since some are little slower that others in understanding or reading comprehension:
1. The vehicle is a '96 993.
2. The 993 immobilizer ECU communicates with the DME ECM over the K-Line and transmits a unique
code to allow the ECM to start the vehicle, i.e. energize crank relay, & begin engine signal processing.
This can't be bypassed without changing (re-flashing) the ECM programming.
3. The '96 993 DME ECM can't be re-flashed, as stated MANY times here on Rennlist.
Bottom line (again): Not Possible!
But when one has limited knowledge about anything other than what shift **** to buy,
suggest that a new ground cable is the solution, right?
And if still not understood, then read here: https://rennlist.com/forums/993-foru...mobilizer.html
#36
Seared
In my industry, and I believe others, I have heard "All things are possible, given judicious applications of time and money".
Not possible to flash a '96 DME? Probably correct. Not possible to find a way to bypass the Immobilizer? I think with time and money it could be done. Feasible? Spend a few hundred thousand bucks to create a solution? Not gonna happen.
I think the words "Not Possible" should be replaced with "Not Feasible"
#40
Embedded in all these responses was a reference to a post that Juha found yesterday. It appears to sync up with the high level overview that Lorenfb mentions with one key exception. According to that post there is a way around.
Here is the quote:
The DME must be reprogrammed to no longer need the "ok to start" signal from the immobilizer. Todd Knighton of Protomotive did this for me. I sent it to him Fedex and he sent it back the very next day. He told me that there is a single bit in the code that looks for the signal from the immobilizer and it is either on or off. This MUST be knocked out, or the car will not start if the immobilizer module is removed.
Now, the car will not look for the "ok to start" signal. Great.
Now is this true and or possible or not? If it is true the so-called "Not possible" or "Not feasible" fix did not appear to be too difficult or time consuming. If you have any questions about shift ***** pass them on. I'm an expert
Here is the quote:
#41
Oh and regarding my '74 Targa. That was the Winter Park sinkhole back in '81 another case of my "luck". I did get the car back and later it nearly drove off a bridge but that's another story.
Today's update. Car is atthe shop!
#42
"The DME must be reprogrammed to no longer need the "ok to start" signal from the immobilizer."
Right, as posted many times before here on Rennlist, but only with regard to
the '97/'98 re-flashable DME ECM and NOT the '96 DME ECM which is what
this thread was initially in reference to.
#43
Okay Loren I hear what you are saying and am not questioning it. Just trying to understand what statements that have been made are accurate or not. In the quote we are both referring to the DME ECM that's being referenced was from an early '96 993TT per the poster. Based on that statement do you feel the posters claim was accurate and valid or not?
If we can ferret out posts where inaccurate claims are made that may give false hope it will help everybody out in the long run. Thanks!
#44
Loren,
One other thought. In your opinion, if somebody with a '96 has an immobilizer failure what solutions are open to them? Not to delete the immobilizer necessarily but to get a car that can start. Anything other that switching to the later ECU and those associated issues and expenses, or tracking down a new or used immobilizer?
