993 Forum 1995-1998
Short Clear Corners
Old 01-04-2012, 01:17 PM
JPP
JPP's Avatar
Originally Posted by sdcabrio
Buy the long ones and cut them down. A very simple DIY. I think the first mod I did to my car.
Here's the thread: https://rennlist.com/forums/993-foru...euro+lense+diy
You just slowly and carefully saw off the portion that doesn't fit because of the bumperette. You then seal that freshly cut edge with some fish tank silicone sealant from Home depot. My description sounds like it's a pretty ghetto way of doing it, but it's not at all.
Exactly what I did as well ... bought the long ones through Sunset and cut them down using fine hacksaw blades. I used a new blade for each one, premarked them with washable marker and sealed the cut with fishtank sealant - beautiful. Then I saw a 'purchased' set and they looked 'hacked' to me AND too short.
Old 01-04-2012, 02:19 PM
Opo
Opo's Avatar
Thanks guys, I will do mine this weekend
Old 01-04-2012, 03:06 PM
Van Larson
Van Larson's Avatar
Default 993 us clear corners
+? from Better Bodies--plug and play, no muss, no fuss, no slicing or diciing.
Old 01-04-2012, 03:53 PM
CAHRERA
CAHRERA's Avatar
When I cut mine down I went to tap plastic a purchased a 1/8" thick board and cut out pieces to glue at the ends.
Old 01-04-2012, 05:59 PM
keithgreer
keithgreer's Avatar
The Better Bodies clear's are great. I talked to the owner. They buy the Porsche part from Europe, then they have a jig to cut them down exactly. Then they seal the ends with caulk. Mine popped in very easily. Putting in the new amber lamps is a little tricky. The bulbs they included didn't work for me so I got some silver tipped ambers on a specialty bulb site (found the link on RL).
Old 01-05-2012, 08:55 AM
boursachi
boursachi's Avatar
i deleted the bumperrettes they are the ones that need to go!
before:
mid-way
after
Old 01-10-2012, 05:00 PM
hchc
hchc's Avatar
before:
mid-way
after
I'm looking to do the same.
Can you elaborate on the "after" pic regarding the bumperette holes? I see that you have cut out a piece to cover the existing bumperette holes. Did you cut the piece from the original black plastic piece? and how is it attached to the bumper?
Might be a good interim solution until i get the holes filled and painted. Thanks.
Old 01-10-2012, 05:19 PM
TheOtherEric
TheOtherEric's Avatar
+1 for buying the long ones and cutting yourself. An easy project. Just don't cut too fast or you can crack the plastic. BTDT.
Old 01-10-2012, 05:23 PM
Resident Sicko
Resident Sicko's Avatar
Ditto on the ebay knock offs. Figured mine would get a lot of rocks, so no logic in spending big money on the others. Cutting down and sealing was a snap.
Old 01-10-2012, 07:45 PM
Al Z
Al Z's Avatar
Hello Mark,
I sent you a PM. I am also located in St Louis.
thanks,
AL Z
Quick Reply: Short Clear Corners
