speedline alessio fitment?
hi
i am looking at a set of speedline alessio's
in these sizes:
FR 17 x 8 ET40
RR 17 x 9 ET50
seller claims orig for boxster fitment.
any issues on a NB 993 in this size?
wondering if the fronts maybe too low offset?
would this particlular style clear brakes too?
thanks john.
in these sizes:
FR 17 x 8 ET40
RR 17 x 9 ET50
thanks john.
the rears will definitely require you to roll your fenders and will also depend on tire size - someone here had mounted the boxster rear 18x9 ET52 w/265 which required rolling; the front will fit with up to 235 and may require some slight rolling - I'm using 18x9 ET40 with 245.
david these are 17".. still need to roll?
or is that more contingent on width
rather than wheel circumference?
i guess a 17" tire fitment would just
create the same total circumference
as an 18" that had narrower sidewalls.
