Billet Valve Covers and hanging spark plug wires
A few years back I joined the group buy on billet valve covers. The buy came with new seals (which I needed, the lowers were dripping heavily) and bolts.
Installed them, and the only thing that bugged me was the lack of support for the spark plug wires. I almost went back to the plastic covers because of that... it's been gnawing at me ever since. I preferentially oriented the wires to eliminate them touching each other, but still, it just wasn't as perfect as I'd like.
Recently I was Christmas shopping for myself, and came across spark plug wire clips for the lower valve covers on the Pelican site (p/n 964-602-559-00-M100).
Only $0.75 a piece, so I ordered six of them. Should be here in a few days.
Hope this helps other perfectionists out there!
As for my other "gifts" to myself... Rennline solid subframe mounts, SSK short shift kit from Mark/Darin, and Weltmeister solid tranny mount. Hopefully I'll have them all installed before Christmas, making my real gift that first drive!
I do not understand your problem.I have Hag. upper and lower on all three of my 993's and have never had any problems.The Eagle Day lowers do not fit a twin turbo with out modification they are too thick.I have never had any running problems and my RS clone gets used all year long with no lower engine cover.The plug wires get covered in mud/snow and salt.Still no problems in four years.The Eagle Day just do not make $ at 40% more.What exactly is it that you do not like?The wires are to short to touch each other.
As a added bonus, they even come with wire holders.
But in the interim, I'll use the clips to better manage the plug wires.
Did you install new wires?
The seals lasted to 65K or so before they started leaking, so it was already taken care of at that point.
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
It's all about making the engine look solid.Plastic looks cheep.That's the bottom line.The VRAM manifold/case / cylenders / fan are all metal of some form.The valve covers were metal for thirty plus years.The reason the 993's are plastic is because the eastern influence on the bean counters.That heat dissipation is just an excuse to make an extra $50.00 per car.Why fight reality.Alex,you know you want them.Live it up a bit!BUY what looks right.
And in the end, why replace what works. My OEM covers don't leak, at least not after replacing the fourteen-year-old rubber seals that had hardened years earlier, they're not warped (urban legend), and they look great...not that anyone can see them, or the Hargett or Eagle Day valve covers.
Hargett 993 valve covers...
![](http://edelweiss.smugmug.com/Cars/Porsche-Technical-Stuff/Temporary-Pics/i-2hV7JLR/0/O/Hargett-993-Valve-Covers.jpg)
Eagle Day 993 valve covers (available in various colors) and finned to dissipate heat...
![](http://edelweiss.smugmug.com/Cars/Porsche-Technical-Stuff/Temporary-Pics/i-ZF2WrHt/0/O/Eagle-Day-993-Valve-Covers.jpg)
And my bone-dry OEM Porsche 993 valve covers with my new self-made Beru silicone copper ignition cables
![](http://edelweiss.smugmug.com/Cars/Porsche-Technical-Stuff/Beru-Ignition-Cables/New-Ignition-Cables/1252201572_XSJ5o-L.jpg)
You know I am immune to Kool-Aid. BUT...whatever turns everyone's crank.
Mark, I got an e-mail notification to this thread that you had posted a reply looking for a pic to my valve covers...but I guess you deleted the post after seeing it.
In any case, that pic was taken a year after replacing the valve cover seals. Note the clean tops of the heat exhangers. But I will report when they do leak.
I got an e-mail from Andreas. He reports that his are still bone dry after replacing the valve cover seals some 5 years ago.
I am also keeping track of which of my original spark plug caps are failing; so far they are 16 years old and all are still operational, but I will also report when one or more do fail.
it is a non-hardening sealer
of course, you can do as you please
I'll be standing by
I have no doubt they will stay dry a very long time. Years. No reason why they shouldn't since your valve covers were perfect.
there are other reasons people choose to replace the VCs (we know, you are "immune") and that is obviously OK too. Your choice.
There are also choices out there when it comes to replacement VCs, with corresponding prices. Eagle Day are quite a bit more $$$
see, it's all about choice.
there is often more than one right answer.
it's a wonderful thing, choice
hard to swallow, I know, but there it is
have a great day...
I know I will, taking the day off of work so I can work
spending the day dropping the lump on a 993
