Sunroof drama
I knew this would be a problem before I even started the job, but I still went ahead anyway. I read the threads about it too.
I replaced the felt seals and it looks good. The problem is the roof is low now when it's closed. Where is the adjustment for the height?
When I pull the cover back up and clip it back in it's feels really tight, and the roof is very slow to open or close. When I leave the cover off the roof is great.
Have I missed something really obvious?![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
Thanks for anything you have!
This will sound obvious, but take a look at the sunroof mounting brackets and ensure that you have them mounted properly (Compare to a photo in one of the DIYs). I had a similar problem when I replaced my gaskets and if memory serves, I didn't have the brackets installed properly.
Good luck,
Terry
Good luck,
Terry
Thanks Terry.
I thought I might have had the brackets upside down. I might have to check but I was sure I had it right. Will look at the DYI again.
Cheers
Cheers
