993 Forum 1995-1998
Oil pressure gauge
Old 12-08-2011, 11:49 AM
Slow Guy
Slow Guy's Avatar
Originally Posted by rwm
I only drive @ 3,000 to 4,000 miles per year. Do you think that I should remove the 0 -40w or can I wait till next year? RWM
I will be the contrarian here and suggest you drop the oil from the crankcase only. With the engine stone cold you're only going to get ~3 qts. out from that drainplug only. Then top it back off with Mobil 1 V Twin 20w50 which has a higher ZDDP value in addition to viscosity than 0w40.
I've done this before, with a stone cold engine you're not going to get the gusher of oil like you would on a hot engine and it's very easy to limit the drainage.
Old 12-08-2011, 12:02 PM
rwm
rwm's Avatar
Thanks all. I have an oil change set up for tomorrow. The gauge is now not pegging above 5. Runs between 4 & 5+. ? It will be interesting to see what happens, if anything, when I get the 0/40 out and the 15/50 in. RWM
Old 12-08-2011, 02:40 PM
rwm
rwm's Avatar
Ran some errands at lunch, gauge now working fine. Bizarre. RWM
Old 12-08-2011, 03:12 PM
cpdjfd107
cpdjfd107's Avatar
Did you remove any oil or the gauge just went back to normal function on its own? It doesn't peg with key in ignition anymore either?
Old 12-08-2011, 03:24 PM
ca993twin
ca993twin's Avatar
You won't notice any difference (perhaps a bit less "rattle" noise when cold, and a touch more oil pressure when hot), but your engine will be very much happier for the long run.
Old 12-08-2011, 03:27 PM
rwm
rwm's Avatar
Just went back to normal. Does not peg with key turned either.
Old 12-08-2011, 04:13 PM
ca993twin
ca993twin's Avatar
It sounds to me like you will be getting yourself a new sender... next time this one fails.
Old 12-12-2011, 12:10 PM
rwm
rwm's Avatar
Well had the oil changed out Friday and the oil gauge stopped working again and has not returned to normal. Any idea on what this "little" job might cost? RWM
Old 12-12-2011, 01:23 PM
BlackCar
BlackCar's Avatar
For most services, the better choice is to find a good independent mechanic who knows our 993s or DIY. Any dealer mechanic under age 35 was in high school or trade school when the last 993 was produced. For instance, a 993 oil change takes effort. Besides getting the correct weight oil, once you add oil, you need to run the engine until it's at operating temp, then add the rest....in order to get an accurate fill. Adding 12 quarts cold is an overfill.
I've done the oil in my 993 for the past 12 years. It's not that challenging, but it takes a good 1 1/2 hours. But then I know it's done correctly. Check out p-car.com for a diy if you've not been there yet.
Quick Reply: Oil pressure gauge
