TechArt Formula 18s on the Bay for WB
Never too old to learn, but I'm hopeful it will happen someday. I don't understand. I have 8.5" ET50 on my front and 10.5" ET60 on my rear. The ebay wheels are ET50 front, and ET42 in back, but with 15mm spacers in back, why wouldn't they fit a NB? (the difference between 57mm and 60mm would seem to be sorta trivial. What's missing?
So, it is possible to mount a NB wheel (ET60) on a widebody car (ET42) with a spacer, but you can't do it the other way around.
The foregoing example refers to the rear wheels.
The lower the ET, the closer you get to the fenders' well. So, the WB can fit an approx. 39-46mm offset (ET). Add spacer to an ET60 will reduce the offset, therefore fitting WB cars.
Obviously I have too much time on my hands... :-)
Here is a diagram of the two wheels. See how you can put an offset 60 on a WB car using spacers AND why you CANNOT put an offset 42 wheel on a NB car?
__________________________
NB WHEEL
>>| center of wheel/hub
offset 60
________________
WB WHEEL
>| center of wheel/hub
offset 42
___________________________
Now, I hope you are more confuse than ever! ;-)
Dave: Thanks for the explanation. Makes sense,
Red: Thanks for the diagram. Helps a lot.
The pisser is that I was too lazy to check my bookmarks, but not too lazy to post a couple of meaningless pix. So much for recollection. Here is what I would have seen if I had checked first
http://www.1010tires.com/wheeloffsetcalculator.asp
Thanks again for the clearly much needed help. Appreciate it.
You probably will reach a broader audience with a new thread.
