993 Forum 1995-1998
Varioram removal
Old Nov 22, 2011 | 11:41 AM
KMASS993's Avatar
KMASS993
Default Varioram removal
I am thinking about pulling my Varioram assembly to address leaking upper valve cover gaskets, get my injectors cleaned and replace the engine pad. Has anyone done this? If so, any good DIY instructions out there? I've done a search and couldn't really find anything. Any help would be appreciated.
Regards,
Kevin
Old Nov 22, 2011 | 11:52 AM
JM993's Avatar
JM993
Regards,
Kevin
The DIY installation link in my sig might help - just reverse the steps.
Cheers,
Joe
Old Nov 22, 2011 | 12:13 PM
geolab's Avatar
geolab
been there done that, would not do it again, would drop engine. Hardest is the accelerator cable. You could spend so much time trying to put it back.
here is the old thread
https://rennlist.com/forums/993-foru...-went-bad.html
if you need instructions, I can write a DIY and it will be a ROW diy. No SAI as you can see
Old Nov 22, 2011 | 12:50 PM
axl911's Avatar
axl911
The trick is to loosen the engine two rear mount bolts but not remove them completely (support engine /w jack while doing this). This will give you almost an inch in room.
Next, remove airbox, rear blower, etc. Loosen the 6 intake runner clamps which hold the varioram to the engine. Then just pop off the varioram and let it settle down to next to the intake. This then will give you plenty of room to reach back and undo the accelerator cable.
Old Nov 22, 2011 | 08:08 PM
KMASS993's Avatar
KMASS993
I thought it would be relatively simple but at this point it may make more sense to drop the engine.
Old Nov 22, 2011 | 10:03 PM
IXLR8's Avatar
IXLR8
I take it you are removing the Varioram to replace the engine pad, because if it is anything like my non-Varioram, the other two tasks can be done very easily with the intake in place.
Old Nov 22, 2011 | 10:22 PM
KMASS993's Avatar
KMASS993
Mainly, also, the car is inside for the winter so I can take my time. I would rather have an easier time reaching all these things as opposed to trying to squeeze and contort myself through our lovely but tight engine compartment. I know how that feels changing all plugs an wires engine in!
Old Nov 23, 2011 | 03:03 AM
CalvinC4S's Avatar
CalvinC4S
Sooo much easier to drop the engine 12" or so.
You could have easy access in very little time, no need to pull it all the way out.
Old Nov 23, 2011 | 03:43 AM
JM993's Avatar
JM993
Agreed.
In fact, I was able to install my Vram without dropping the engine at all. Made possible by deleting the cruise control which was useless to me anyway. It's really not that hard.
Old Mar 14, 2012 | 11:45 AM
shadow993's Avatar
shadow993
How do you drop the engine 12"? I'm looking to do plug wires, upper lifters, plugs and maybe Sai
Old Mar 14, 2012 | 12:28 PM
KMASS993's Avatar
KMASS993
Dropping the engine does not make this job that much easier. In the end it is probably equal to the little bit of extra time figuring around certain elements of the engine compartment.
Old Mar 14, 2012 | 01:01 PM
axl911's Avatar
axl911
Been there done that. Dropping the engine 12" or completely wouldn't make the WHOLE job easier. But lowering it 1" by undoing the rear engine mount bolts would give you the room needed to get to the various components and take the varioram intake out.
Aftrer that, replacing wires, valve cover, plugs, sound pads, SAI valve, intake breather gasket, engine wiring harness etc. are a cinch.
Look at all that room!!!
