New project for me, yet another 993 RS Clone for you :-(
#242
Front brakes are 928 GTS calipers (same as Carrera RS or 993 Turbo in size) that are black with same Porsche font as original. I had to flip the crossover pipe and bleeders so orientation correct for 911. Discs are floating Zimmerman 322 mm with aluminum centers.
#243
I just spent most of today reading and re reading thru this... thanks for the lessons.
do not forget to include this thread about your glass https://rennlist.com/forums/993-foru...tallation.html
#244
Agent Orange
Stock rear brakes with cut away backing plates and proportioning valve eliminated.
#245
I owned a 964 Carrera Cup which has dimensionally and hydraulically the identical set up (along with the 964 RS and RSR as well, except a larger master cylinder) to what I am running here and those brakes are fine for me, so I decided not to add the unsprung, rotating weight of larger rear brakes.
#246
great build thanks for sharing
#248
Yes, but I didn't write it down. If memory serves me it was ~ 2 pounds lighter than a 993 Turbo disc with the bolt up steel bell. As you can see quite a bit of disc assembly is replaced with aluminum if not eliminated altogether by the spoke construction.
I wish the reading on scale was in the picture
[IMG][/IMG]
[IMG][/IMG]
#249
Great progress BTW! Nice to see it coming together with detail and thought.
#250
Won't front/rear brake bias be negatively affected without the correct proportioning valve in place? I remember when I installed the 928GTS front calipers on my 951, I needed to also switch the PV so that the bias wouldn't be out of whack.
My chassis here also has 4 channel ABS option instead of normal 3 channel - a 964 Cup is only 3 channel.
#251
[IMG][/IMG]
[IMG][/IMG]
993tt 20.4#
Zimmerman 18.6#
all the 993tt disks i've had match your #
#253
the f/r torque bias ratio for a stock 993 w/o(w/) p/v would be 1.604(2.970)
Bobs is 1.659 or slightly more front biased, note the 911 thru '83 was 1.579 w/o p/v
All of the 964Cups and early 993Cups also used pretty close to this setup w/o p/v
just for comparison late 993Cup and all 993RS are 1.426(2.64)
On my cars 993RS is great for track because it diverts some of the load to the back, my street car w/ the same brakes 993RS and no p/v has also been fine though not used as hard
low ride height, 4 channel abs and an effective lsd help to be able to use more rear bias, more front is safer on the street which is why Porsche(and all other oems) tend to go that way
#254
Why do I feel so left out!
Awesome Build - Love the attention to detail.
Gives me some ideas… Just need the $$
