FS: Classic Grey 4 Spoke Steering Wheel
I'm selling my Classic Grey 4 Spoke steering wheel that came on my '98 Cab.
It was removed when the car had 24K miles and the PO kept a steering wheel cover on it all the time to protect it from the Las Vegas sun. So... It looks like new! Complete with airbag.
$250 including shipping to lower 48. Paypal OK.
thanks,
Scott (916) 773-7749 aerocrosby@comcast.net
thanks,
I'm interested if this will fit my 95 C2. I remember something about an airbag change between 95 and 96-98 I'm pretty sure the hub is the same, though. Can someone save me some search time and verify that it will fit a 95. Thanks, Derek
Coming with the airbag you should not have a problem. It's when you have to interchange the airbags there is the difference between the 95's and the late model 993's. The issue is the airbag mounting frame and the deeper offset between the early and late models.
Looks like there is another difference - found this in a thread from March:
"Also, the splines are aligned differently in both versions. So, if your steering wheel was perfectly centered and you get the other version, you may find that the wheel may not be centered without an alignment as the splines are a bit off."
