993 Forum 1995-1998
Best way to attach steering wheel crest
Old 10-20-2011 | 10:28 AM
Quadcammer's Avatar
Quadcammer
Default Best way to attach steering wheel crest
Morning gents,
now I know the crest will likely end up in my forehead anyway when I run into something and the airbag deploys, but nevertheless I've purchased one and am trying to find out the best way to attach it.
I got the 356 badge with the pin, which will be ground down, and the gentle slope of the badge flattened.
At that point, should I be using a hot glue gun, silicone adhesive, etc? Its going on a vinyl flat airbag cover (raid, fvd whatever).
Thanks.
Old 10-20-2011 | 11:37 AM
David993S's Avatar
David993S
I did this with my steering wheel - used a 356 hood crest, ground off the pins, flattened it a little, and just superglued it over the embossed crest. I didn't envision removing it so I wasn't concerned with using superglue. Did it years ago and it's still securely attached. If you don't want to superglue it, I would think some silicone adhesive would work fine.
Don't worry, it won't end up in your forehead if your airbad deploys. The cover pops out of the way for the bag .
Cheers.
Old 10-20-2011 | 11:56 AM
Quadcammer's Avatar
Quadcammer
Thanks david, i'll swing by home depot.
How did you assure you got it centered? being ****, if I get this thing on crooked I'm gonna be pissed.
Old 10-20-2011 | 12:10 PM
David993S's Avatar
David993S
My steering wheel cover had an emmbossed (indented) crest molded into the plastic. It was almost exactly the same size as the 356 hood crest, so I just put it over the indented embossed crest.
Old 10-20-2011 | 01:03 PM
Chuck W.'s Avatar
Chuck W.
Hey Oliver.... I used a hot glue gun and used just a small dab of glue. It held well for several years of use. When I sold the wheel I popped the crest off and the glue peeled off without leaving anything behind.
This will also be an advantage to the ER doc that has to pull it from your thick skull.
Old 10-20-2011 | 02:31 PM
Quadcammer's Avatar
Quadcammer
lol, yeah, gotta help out the ER doc.
I have some black permatex, think I'll give that a shot.
Old 10-20-2011 | 05:37 PM
RS man's Avatar
RS man
Make sure you guys post a picture of your forehead when the airbag goes kaboom
Old 10-20-2011 | 06:53 PM
pingwrx's Avatar
pingwrx
Old 10-20-2011 | 06:54 PM
No HTwo O's Avatar
No HTwo O
^Ping, pretty well centered, too. Good job!
Old 10-20-2011 | 09:25 PM
Quadcammer's Avatar
Quadcammer
well, the permatex was a big bust. Went the hot glue gun...took two tries. Worked ok the second time, but I'm not sure its going to stay on there.
Old 10-20-2011 | 09:30 PM
ilko's Avatar
ilko
Agent Orange
My experience with hot glue on vinyl is that it doesn't hold well. It will pop off sooner or later, especially if the temp is below freezing. So just I superglued mine. 2 years no issues.
(And yes, that is a silver crest. Anybody know if it's factory??? )
Old 10-20-2011 | 11:05 PM
Quadcammer's Avatar
Quadcammer
Dammit I'm batting zero...went back to check and the thing fell off at the slightest touch...I don't get why nothing sticks here.
What kinda superglue are you all using
Old 10-20-2011 | 11:15 PM
cpdjfd107's Avatar
cpdjfd107
Quad you need to prep the **** out of the spot with rubbing alcohol or acetone, and maybe even scuff up the area underneath *as much as I hate to say it) if you are having problems. The one in my cab was held on with emblem adhesive (same stuff I use for the rear emblems outside car. I believe it is a 3M emblem adhesive.
Old 10-20-2011 | 11:34 PM
Quadcammer's Avatar
Quadcammer
Hmm I used rubbing alcohol.
Frustrating for such a simple thing
Old 10-20-2011 | 11:47 PM
ilko's Avatar
ilko
Agent Orange
The kind they had at a Midtown deli. Any "super glue," "krazy glue," etc. instant bonding agent will do the trick.
Quick Reply: Best way to attach steering wheel crest
