Trickle Charger Question
Oct 11, 2011 | 07:05 PM
Quote:
Originally Posted by
Cactus
So I'm not sure if the question was answered yet? Good or bad?
Right away, I said something ain't right.
How much time do you allow, after the car is locked, for the light to potentially shut off? If your waiting minutes, it's not that fast. It's more like hours. If it takes days, something is not right.
Is your battery properly maintained? All cells full with distilled water?
Oct 11, 2011 | 08:15 PM
...Stabilization...
Andreas
Oct 11, 2011 | 08:35 PM
If it's the Porsche (or any other) CTEK charger you can leave it on 24/7 as long as you like. You still should check the electrolyte levels in the battery once in a while though - this applies the "sealed" type batteries as well.
Oct 11, 2011 | 08:42 PM
2Many Cars
Depends. Some batteries appear "sealed" which is nothing more that a strip across the top of the battery, or flush caps. Those can be topped off.
Valve Regulated Lead Acid (VRLA) AGM or GEL batteries should not be opened.
Oct 11, 2011 | 09:41 PM
Oct 11, 2011 | 10:01 PM
Noodle Jr.Rennlist Member
Oct 11, 2011 | 10:06 PM
techman1
May want to clean the Idle....
AOW162435
...Stabilization...
Arena993
......Valve........
^^^^May want to check this.
Cactus
Will check my battery.
Whatever...
EDIT: Awaiting another Clint Eastwood pic.
Oct 11, 2011 | 10:09 PM
Cactus
1) Safety glasses/goggles
2) Rubber gloves
Oct 11, 2011 | 10:38 PM
No HTwo O
2) Rubber gloves
3)beer for medicinal purposes
Oct 11, 2011 | 10:44 PM
Cactus
It's that large black, box-shaped thing on the floor of your trunk. Should be just to the right of your spare tire.
I can post a pic from PET if you need it.
Andreas
Oct 11, 2011 | 10:47 PM
AOW162435
Andreas
10 days till you gets yours suckerface!
Oct 11, 2011 | 11:09 PM
Cactus
Ha!
Andreas
Oct 13, 2011 | 10:07 AM
Turns out my battery must have been weak. The charger finally started cycling after a week.
