15-lbs of Carrera Desk Clock...
#31
Moffat, thou art too kind!
Thank you.
As you know, yours will look a wee bit different....
Thank you - I'll answer your PM tomorrow.
I appreciate that.
It arrived Friday, but I decided I'd have more fun carving aluminum with an old Tablespoon. So I sent the machine back.
Thank you sir!
Now, now, let's not get carried away...
Danke.
Thank you.
I'm just a hack. With a Tablespoon.
It was a pleasure working with you, Greg. Let's hope it arrives safe & sound tomorrow.
Very cool - thank you.
I very much enjoy creating/crafting/destroying/visualizing/etc. Always have.
There's a bar?
Thanks!
Neither do I.
Thank you again - hopefully it's still functioning as intended.
Wordsmith.
Adam,
I just returned from a whirlwind trip to Charlotte, NC and am absolutely beat. 7 hours of driving yesterday and 9 hours today. My mind is unresponsive, so I'll address your messages tomorrow. Sound good?
Thank you sir!
Thanks, Nathan. Let's do the same to your oil tank.
When compared to three-toed sloth, yes.
I presume you can present yourself on his doorstep tomorrow evening for an advance screening.
This should help:
Viehlen Dank!
Thank you.
Andreas
Thank you.
I appreciate that.
Thank you sir!
Danke.
Thank you.
There's a bar?
Thanks!
Neither do I.
Wordsmith.
Adam,
Thank you sir!
This should help:
Viehlen Dank!
Thank you.
Andreas
Thanks!
#34
Thanks Andreas for the pic detailing the connections.
I presume you connect the power and ground points up to a female DC connector and then plug in the male ac 12v/250mA adapter to it?
BTW, I am by no means an electronics expert.
