My first oil change on a 993 yesterday
#31
That was a great writeup, but you did not go into nearly enough detail about the second oil filter. Apparently, they are typically welded on, and located several feet deep inside a tunnel of machinery. This single feature caused my first oil change to stretch over a couple days and a run to sears.
Like you, I did not sacrifice a rooster. I was unable to get my hands on one, so I wrung the neck of a raven - it did not seem to help. Maybe the feathers are to be used as an absorbant?
#32
Just an update. I did my 3rd 993 oil change yesterday. On the advice of BobbyT on the first page I switched from sacrificing a live rooster to the 10 shiny dimes strategy.
I am pleased to report my oil spillage is down probably 75% vs. the first one I did. Exxon stock prices should fall today.
I did manage to get a good amount of oil in my hair when changing the 2nd filter though. As a result I need to add a HAT to the tools list on the front page "how to" list.
#36
I just did an engine and tranny oil change today and really enjoyed this. I did this the 3rd time and it is always fun and rewarding. I used an universal auto-adjusting oil filter wrench for the first time that was recommended in this forum. It made it so easy, to get the second filter out.
http://www.sears.com/craftsman-unive...p-02820523000P
Not need to remove the oil line. After I loosened the small filter, I poked a hole in to drain the remaining oil. The mess was very minimum when I removed the filter. This is an easy DIY and the most complicated thing is to get the car jacked up. However, I feel so secure with the Esco stands! At some point, my garage will have a lift ...
#37
A benefit of removing the oil line is that you get more oil out - quite a bit since its what's left in the bottom of the tank, line and oil pump. I do it very time.
Cheers
MIke
Cheers
MIke
#40
What's the fun in that? Besides, I find that filling the 997 to the proper level is a challenge given 1) no dipstick 2) you have to wait for the computer to cycle for a while before it displays the oil level.
(I actually like doing 997 oil changes - like you said they are a snap and if you know exactly how much oil to put back its all good...).
Cheers
Mike
Cheers
Mike
#41
I laugh every time I read your first post on this. Being new to 993 maintenance, do I even dare try to attempt an oil change with the car only on jack stands???
#44
There are so many great DIY descriptions out here and if you get stuck, there is always help on this forum. I only work under jack stands because I followed a recommendation from rennlist: ESCO stands. They are safe, safe, safe.
#45
I am still running on the 5wX0 synthetic I had in the car when I purchased it in September 2011. Its really not that bad since the car is parked during winter. I have experience with my past 89 Carrera but the 993 just scares me after reading these threads.
My plan was to use a left over case of BP 20w50. I noticed you are using a mix of BP 20w50 and 10w30. Is it a 50-50 mix?
