removing rear suspension
#47
front crossmember off
calipers off
release handbrake cables
undo subframe front chassis and upper cross memmber
and drop it all down
undo the various arms once its off
teh scene of devastation so far
dropping the other side
wiggling the top cross member out as well for a refurb
#50
more brackets cleaned:
more miscellaneous heat shields wire wooled and cleaned
leading bumper brackets given a coat of 4941 rust prevention wax
and hung to dry
the rest of the black powder coated parts given a few thick layers of FK1000p to bead off the water
same goes for the PSS10, and given a general clean and a small wire wool at the bases
and hung to dry
#51
REMOVING THE AC
homing on the on condenser
disconnecting the lines
there she is, quite heavy too
dessicator removed as well
condenser bracket given a good cleanup and coat of wax
a big gaping hole !
a big gaping hole !
#52
now for the big heavy compressor ... should make the engine bay a lot neater
undoing the lines from the NSR arch
tease the thing out
oull out the support bracket with a pair of very thin arms
now on ebay !
tease the thing out
now on ebay !
#53
heater flaps
sorted, with a nice patina
after a 24 hour soap soak ... now off to be degreased and scrubbed
getting somewhere .... abs and brake lines and HT leads and fuel lines all extensively 303'd !
making a start on the big thick black engine and box degrease
[footnote]Edited by jackal on Friday 23 September 19:56[/footnote]
#55
new side support heatshields, £60 a pop
new RS M003 clubsport strut brace (a 964 part)
plated silencer straps ! Came out better than expected
We all love new shiny things.
blasted
and lacquered
early next week they'll get rebushed with RS shore 85 inserts
new front RS top mounts
and the rears
Ooopss... the RS spring cap doesn't fit inside the smaller Bilstein PSS10 springs. That'll be £80 down the swanny then. Time to go to my man on the gypsy site in West Molesey to get an aluminium copy fabricated that will fit properly.
and heres the remains of that pesky ball joint that was impossible to split .... GTone took one and half hours labout to get it off the upright ! Much use of large very very hot flames, massive pullers, guns, big huge mallets and tons of swearing.
#60
I'm honestly stunned, amazed, in shock as I read this thread. You, sir, are amazing! Some years ago I did a frame off restoration on a pickup truck.....I was proud of it, but your work is far beyond mine! WOW.
