Alternative switch for oil cooler fan override
I did the oil cooler fan bypass today and used a switch that may be a better choice than the 944.613.235.00 switch mentioned in the pcarworkshop website. I used a 928 613 240 00 This switch needed no modification and snapped right in the center console. It's plain black. I bought a used one on ebay a while back and it comes clipped into a larger piece that makes it look too large to fit into the center console. Unsnap it from the outer piece and it clips directly into a port in the center console. No modification needed.
I'm going to look around for someone to make a fan symbol out of vinyl to put on it. I'll keep everyone posted on what I find.
Randy
Randy
I decided to use the 944 defrost switch (944 613 117 00) but need help on the wiring. Which connectors do I use on the switch? Looks like there's a light on the switch as well!
If I had to do it again, I'd use goo gone to wipe off the hazard triangle and try the nail salon trick
I dig the hazard because of its activation light.
edit. link added
https://rennlist.com/forums/9683196-post26.html
