993 Forum 1995-1998
Alternator and engine fan question
Old Jul 31, 2011 | 07:34 AM
haygeebaby's Avatar
haygeebaby
Default Alternator and engine fan question
Guys
Correct me if I'm wrong here - I have a query about the alternator/engine fan/ pulley assembly.
The alternator shaft needs to spin to enable it to function - in this case to re-charge the battery. The engine fan sits around the alternator shaft via the fan hub bearing. The engine fan is then bolted onto the pulley shims, and the engine fan will spin as long as the the engine fan belt is intact and is being powered by the engine crank pulley.
But the engine fan bearing hub, nor the belt shims are connected to the alternator shaft in any way. They can spin freely of each other. So how does the alternator shaft spin - if it is not tied to the pulley in any way ?
Old Jul 31, 2011 | 07:52 AM
guards red's Avatar
guards red
'cause it has its own belt? Not being facetious here, but you do have two belts right? Three if you have air con.
Old Jul 31, 2011 | 07:56 AM
d ward's Avatar
d ward
They are independence from each other and run at different speeds, that's why there are two belts
Old Jul 31, 2011 | 08:33 AM
haygeebaby's Avatar
haygeebaby
I had three belts when I was running the standard setup.
When I ran the RS hub I had only two.
With the SC I have two as well.
But there is still nothing connecting the hub, fan, or belt shims to the shaft. The crank shaft on the other hand has a pin that locks the crank pulley to the shaft. I looked at the PET and there is definetly no pin for the alternator shaft to the fan or pulley.
I know it all works - and I am assuming that the hold on the shaft by the shims is tight enough to keep the alternator spinning.
Old Jul 31, 2011 | 10:22 AM
guards red's Avatar
guards red
If you still have the RS Hub then the fan and alternator are locked together and run at the same speed. You suffer a little undercharging at idle but nothing major.
Old Jul 31, 2011 | 09:55 PM
haygeebaby's Avatar
haygeebaby
No matter what type of hub you use - they all sit around the alternator shaft and are not directly locked to the rotation of the shaft itself.
So logically - the fan will move - but how does the alternator shaft move?
This is what I'm trying to get at.
Might it be the contact from the friction from the shalf bolt on the front of the pulley.
