engine tray retaining clip
the engine tray retaining clip behind the rear passenger wheel seems to have disappeared. Did my first oil change, everything went well thank you very much; went to tighten the screw holding the engine tray to the body and it would not hold. I have looked at the parts diagram and there is supposed to be a retaining clip to screw into. I can't determine how to replace it, if that is even possible; is it gone, stripped? Anyone with any ideas to pass along would be much appreciated.
Sorry, no idea (and can't check on my car because it is >10,000km away from where I am right now) but I have an inkling that you will soon receive suggestions about removing the engine tray altogether...
Chris
Chris
Here is a pic of the one on the right side engine tin. Its that silver colored retainer just under the power steering hose and forward of the hole that the lower spark plug cables go through. There is one just like it on the left engine tin.
I think the majority of us recommend removing the engine tray (at least for summer months). Personally, my transmission tray needs a retaining clip for the center retaining screw. This is the retainer that stays on the car bracket even when the tray is off. Just haven't taken the time to look up the part yet.
Duh!
Thanks for the pic Alex
I got a good view of it, it is opened up to where it needs to be replaced. I'm not sure how hard it will be to get to, my first guess is it won't easy. The engine and night time temps are too hot to deal with it right now. I'm hoping the other screws will carry the load for now.
Hi
I had a simular problem, the clip was still there, but the centre had been push-up, hence the screw would not catch.
Just need to push the centre of clip down from the top, that is from inside the engine bay.
This might not be the problem, but worth a look.
very common.
if not, the clips are available and very inexpensive
we keep extras at the shop, just in case
