Valve cover bolt snafu
So I decided to take on the 'simple' job of replacing the valve cover gaskets since I have a small leak from both covers. All the bolts came out easily except one, where I guess I was a litle hastly in seating the Snap-on 5mm allen socket, and I rounded it out
Luckily it's one of the more accessible ones. What's the best option for shifting it now (assuming someone has run into this before)? I though about cutting a slot across the head of the bolt and using an impact driver with a flat screwdriver bit.
All suggestions glady accepted
Cold chisel worked with mine. I tried cutting a slot in the bolt head with my Dremel tool and using a screwdriver first, but that didn't prove effective.
These bolts are pretty soft, and stripping the hex socket is quite common.
as others already suggested, get it moving with a small chisel or vice grips if you can. Once they are cracked loose, they usually come out easy
Drill the head off as a last resort. Once the VC is off you can grab the nubbin that is left with pliers
those little buggers are soft... Someone should spend copious amounts of time re-engineering this $1 part
had to do something like this on the muffler bracket bolts before... Nasty things
Well it's out - I tried one of those fluted bolt extractors first, and because the bolt is so soft, all it did was cut a nice bevel on the head. The winner was the hammer and cold chisel - 5 or 6 sharp taps and it was free. Thanks all!
So dumb question... I am assuming that with the chisel you are tapping the head of the bolt off. Do you then drill out the shaft after removing the valve cover?
I had trouble with the top rear bolt on the driver's side lower VC, but stopped before rounding out the head. Just trying to figure out the best approach for removal.
Once there is some rotation they almost always come out easy.
another tip is to tap each bolt with the allen inserted prior to attempting to remove it. This is before there is trouble, of course.
hopefully all of that makes sense
yes exactly - just position the chisel on the edge of the head and hit it so it has the effect of turning the bolt. Once you break it free it spins by hand easily. Seems the secret is to break the bond on these first - so for the other side I will set the 5mm allen socket first and give a good tap with a hammer to help that process before applying pressure.
