Air Duct for Engine Cooling Fan Question
Hello,
I was cleaning up my engine compartment today and notices that I have a crack in my air duct. I searched here and it seems to be a fairly common problem and pretty easy fix. My question is should I not drive the car until I get the part replaced? Will I do any damage?
Thanks,
Chris
Thanks,
Chris
Easy DIY but there are (2) different parts, one for non-varioram and one for varioram. The one w/o varioram has a 964 part # IIRC. A search should help you find the correct part #. I had this issue and put some duct tape over the hole until the part arrived.
Yes, there are two versions of air duct but you best verify the one on your car before you order a replacement. I just replaced one on my 1995 non-varioram C2 and it took the 993 version.
bart1 posted the following photos recently;
top: 993.106.403.00
bottom: 964.106.403.02
![](https://rennlist.com/forums/attachments/993-forum/381535d1251402418-engine-compartment-question-dsc02473.jpg)
![](https://rennlist.com/forums/attachments/993-forum/391392d1255098964-heating-fan-bypass-piece-dsc02474.jpg)
Hello. Thanks for all the replies. I ordered it from Suncoast and I ordered the non varioram version. From the search I did here it seems that early builds like mine use this one. Please let me know if I'm wrong.
Thanks again,
Chris
Thanks again,
Chris
The air duct part number has nothing to do with vario ram.
It has to do with the fresh air intake grid on the left side of the engine bay. IIRC this was added around june-94 production date (still MY 95 cars). If your car has a fresh air intake you need the 993 number, no intake uses 964 part #.
Too answer your original question I would tape over the tear if you need to drive it.
