No Start / Rough Start When Hot
Can does not like to be real hot and won't restart when full up to temp without pumping the throttle liek crazy. It will then stumble and fire, running rough for a few seconds before it levels out and runs great. ICV was recently replaced too. Anyway, I am thinking Head Temp Sensor. Any other ideas or comments before I start throwing money at it?
TIA, John
TIA, John
Update. No start cold.
Fuel pump does not run with DME relay. When jumpered it runs but will not start. There is fuel in the rail though.
No spark.
DME? Where to go from here?
No spark.
RL Technical Advisor
Got a spare DME relay????? Thats the place to begin. Remember, this relay powers both the DME & fuel pump.
If that doesn't work, its time to check crankshaft reference and position sensors.
There is no spark and no fuel intermittently at start-up. The Fuel pump is not running with the ignition on. If I jumper the relay the FP runs but there is still no spark. So it seems to me either the DME is bad or the mentioned reference sensors are working intermittently, more likely.
My only concern is it is just at start-up, once running it is rough for 5 seconds and the runs great for the duration.
