Loud Pop, Intake Backfire
Need Help. Sometimes, generally on a warm start, there will be a loud pop - backfire up thru the intake manifold. It's strong enough to pop off the entire manifold from the engine and the throttle body. This has happened several times.
First time I checked the wires and found 2 in the wrong position on distributor cap. I fixed this and the car ran great. Fast forward two weeks. The same thing happened again. I triple checked the wires again - they are fine.
I recently changed all the wires, plugs, but not the caps/rotor. The caps/rotor have 30K on them. MAF has been cleaned and working. Fuel injectors were recently checked and cleaned.
This seems to be a timing issue but I am at a loss for what to check next. Any ideas? Flywheel sensor? Other timing issue?
Perplexed!
Perplexed!
Checked Distributor belt. It is fine. But, Take a look at the rotor and caps. Does this look like it could have caused the timing issue? I'm gonna replace because they look black and corroded. Is this evidence of arcing? Opinions Please!
Hi Vorsicht, did you manage to solve the problem of the intake popping off? I recently rebuild a 964 engine and had the same problem. I've replaced the belt in the distributor including its caps, cleaned injectors, replaced all intake rubbers and fuel pump, replaced air mass meter, flywheel sensor.... Im reaching an end here.
Does anyone has an idea what else it could be?
J_MENDIETA (04-03-2024)
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Another thing to check would be the cylinder head temperature sensor. Measure the resistance at a given temperature and see if it correlates to what it is supposed to. The head temp sensor plays a big role in fuel injection mixture on these cars as I have learned in the past chasing down a similar problem.
UPDATE: I've measured the fuel pressure, 4.5 bar. far too hight. after switching off, pressure drops to 0.5 and holds there. Not enough to restart.
I've ordered the fuel regulator and I'll keep you posted on the outcome.
