Valentine One power chord repair question
The phone jack connector broke and the manual says it uses a typical phone chord. I have a few lengths of it with a brand new connector attached already. Is there a way to clip off the bad connector and a few inches of wire and replace it with a new length of wire with a fresh connector without soldering etc?
Yes, yes. I agree.
To repair your V1 CORD, you might want to go by Radio Shack or Fry's Electronics and see if they have the new plugs and a crimping tool. You could fix your cord and not have to pull out your wiring.
Good luck!
Good luck!
Often the crimping tool is very expensive. I have seen the tool cost as much as $50. you can pick up a handful of the connectors from Radio Shack or Fry's Elecronics for less than $5 like mentioned above. If you don't want to pay for a crimping tool ask someone that does telephone/networking cabling to crimp it on for you it would take them 10 seconds to do with the correct tool and would probably not even charge you if you brought in the connectors. Try a local computer/networking store/installer that do network wiring etc.
Nick
Nick
Phone cords are pretty inexpensive, I'd think that you'd be way ahead if you just went out and bought one than trying to chase down all the tools to repair something that's pretty much readily available, almost disposable with people not keeping land lines any more.
You can get a cutting/crimping tool for a few bucks, some cord and some plugs. No need for the $50 tool. I got one at radio shack or Lowe's. Just make sure you don't put the plug on backwards, you'll blow a fuse.
It's amazing that stores accept returns on tools. Chains can absorb it. Smaller guys (are there still any?) don't.
