The journey to Vesuvius.....Not Back in Black
#31
RL Technical Advisor
Together with that nice motor and the RS LWF kit, you won't know what hit you.
#33
I hope your health is better. Thanks for all the work and information you have so generously provided. She is going to be a beauty when she is done.
Emerald
#35
#39
Well I guess it is time for a quick update. I received the parts from FDM and rebuilt the front diff. I installed it, then installed the rebuilt steering rack. I replaced the lines to the rack while I was at it. The next step will be the front end. I decided to replace the tie rods,drop links, and ball joints on the front. The entire front end will basically be new. Once I have it all together, I will drop the suspension, and replace the rotors as well. Slow but sure.... she is coming back to life. She should be pretty tight when done.
Emerald
Emerald
#42
Well.... I have all the goodies on the front end bolted up. She shoild be pretty tight considering I replaced just about everything. I just got the paint for the calipers, so that is next. I will then drop the suspension, paint the wheel wells, then replace shocks, springs, rotors,and install freshly painted calipers.
Pictures when there is more progress.........
Emerald
Emerald
#43
Well, time for a little update. I dropped the suspension, painted the wheel wells, then replaced shocks, springs, rotors,and installed freshly painted calipers. I went with the Koni FSD shocks and MO33 springs.
I dropped the engine and transmission, and took the transmission to my favorite indy for a re-gear. I then did the SSk and Golden Rod combo from Fister.
Today the mechanic came and picked up the engine I built, then had the car trucked to his shop. He will mate everything up when he completes the transmission.
#45
