PSS10 plus what?
Shop is putting my new PSS10 on. I don have the benefit of a local shop liked FD or Viper Bob that has all this down to a science.
What is current thinking on any other changes to make when installing PSS10 on a 100% street car? Just looking for firm, flat handling for occasion aggressive street driving in the central texas hill country![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
M030 or RS sway bars? Bushings? Strut brace? I am just not sure whether these things are necessary with PSS10 or not...?
Oh I hope this gets answered thoroughtly as I've got a set of PSS10 in a box waiting to be taken to a garage and want to ensure I ask them to do the right bits too. I think Walrod bushings and a strut brace (RSR) are key, am less clear on the consensus for sways...I've heard the stock sways from a ROW may be okay for a daily driver (which mine is...a C2S).
When I did my PSS10s, I had M030 sway bars, Wevo black engine mounts, adjustable rear toe links, and front spherical control arm bushings installed.
I replaced the bushings and toe links because they were significantly worn.
If over 75000 mi and considering they are all over 12 yrs old be prepared to replace the front lower control arm bushings with the Walrod or Elephant racing while in thereThey are cheap at around $100 and only about 1-2 hrs extra . You should do a wheel alignment anyway with a shock change.
I have 111000 on mine I purchased it with PSS9 already installed.
I freshened up the front end with bushings last year when doing brakes. The wiggle which I thought was warped rotors was bushings.The existing rubber bushings will be torn by now in most cars. I upgraded the sways to ROW M030(22/20 vs 20/17) I honestly can,t feel as big a difference as I was expecting.Some improvement but not huge. You can add a strut brace anytime now or later.
Jonathan,
Definitely replace the front control arm bushings. Use the red Walrod bushings and I recommend a core exchange as it is cheaper in the end.
I would also recommend upgrading the sway bars. I cannot recall what I used on my NA cars, but I think it was MO30.
One more vote for the front control arm bushings. For your purpose, you will be good with stock sway bars. Safe the money for repairs. When your shop installs the PSS10, make sure that you supply them with extra locking collars. Do a search on rennlist for more details.
The car will be transformed if the stuff is installed and aligned/corner balanced properly. You might add a strut brace later but that is simple DIY.
I thought about the extra locking collars but assume the PSS10 kit has them where the PSS9 kit didn,t. You want 4 collars per side to be able to lock the height and the swaybar bracket in place seperatly.
Set front strut @4 / rear strut @5 tires front at 32 rear at 36
set height alittle higher then RS
Good luck
decide where you are going to set ride height - then be sure the shop can still adjust kinematic toe when lowered. I have found that a major problem with many shops - either they don't do it, or the dealers wont do it on lowered cars. So you should ascertain if they can do that or not. I went with PSS9 and RS sways and like them. A friend of mine we put PS9 on and he had the M030 sways and it feels nearly the same on street. You can always upgrade sways later if you wanted to start with stock - though I recall the front being a massive pain at least for the RS sway change.
Ummm... Coilovers are sexy and peer pressure is a tremendous kick in the *** towards the slippery slope (think heroin here). But. The first and only question to ask is "What do I want the car to do for me and what goal am I trying to achieve by modifying it?).
I would recommend just doing the PSS10s first. If you decide to get more aggressive, you can fine tune with sway bars later. I would go with M030 sways. Less than $400 for a set with bushings and can be upgraded any time (you don't need another alignment for sway bar install.)
As stated above you should check the front lower control arm bushings for play and replace if needed.
And of course a proper alignment is essential.
Engine mounts are a nice upgrade. We only use genuine Porsche RS engine mounts. Wevo mounts are nice and many have used them with success, but we have seen it induce unwanted nvh (noise, vibration, and harshness) on some cars, so we stick with the factory parts and have never had a problem.
You will love the PSS10s!
craig
Great answers here. Thanks again to all.
