993 inactive alarm?
3rd Gear
I bought a May 1995 C4 coupe in Kentucky and drove it back to the frozen north.
The car had suffered some flood damage and the immobilizer was replaced. Unfortunately the code that was supplied with the car was incorrect and it took me a few weeks to reprogram 2 new key fobs (Thanks for all the posts here). I now hear from the dealer that the alarm module will be inactive because the incorrect code was used 3 times. They want $1800 to fix it plus $400 for new fobs +labor.
Maybe I'm dumb..... but all the fobs unlock the doors and start the car and the immobilizer works. The fobs also flash the door LEDs but the horn does not sound when the key is used to open the door. Am I missing something other than the fact that the alarm wont sound - why should I replace the alarm module?
Thanks to all of you for such a great resource.
Dave
Dave
sounds like it's working to me also. I think if you unlock the door with the key it disarms the alarm. So it wont sound if you unlock with the key and get in. try this... take key out of ignition... open door, close door (stay in the car) arm the alarm with the fob. wait until the led's flash slowly then stick the key in the ignition and try to start the car... does the alarm sound? it's been a while since I messed with my factory alarm but I remember when I got the car I had similar issues trying to set the alarm off. i had to outsmart the alarm to be sure it was working...
Nick
Nick
3rd Gear
Thanks guys
I did in fact test the alarm by turning the ignition with the car armed....... yes it WORKS !
So much for a cash grab from the dealer. I just cant believe I would have forked out $2000 for nothing.
I appreciate your help.
Dave
Dave
A dealer told you this? Does that not scare you enough to not step foot in there ever again?
My local dealer was terrible when I needed to buy a couple of worn our parts replacements.
3rd Gear
Thinking about it I suspect that the dealer had given up on getting the code from Porsche in Germany and decided to replace the alarm and immobilizer hence the $2K bill. But he wasnt entirely honest as he just told me the alarm would not work. I wont be going back !!
By the way, the car pictured above is my C4.
Dave
Dave
From following the news from southern Manitoba, I hope you have it parked on some high ground so the car doesn't see flood damage twice !!
good luck,
max
good luck,
max
