993 Forum 1995-1998
Help! Help! My 993 left me stranded.
Old 05-10-2011, 07:13 PM
shadow993
shadow993's Avatar
Default Help! Help! My 993 left me stranded.
Turn the key at first and got one single click, as I turned the key .. It did this a few times!
Now nothing.
I replaced the relay, tried my spare remote and key, and I tried jumping the car. I get nothing but lights on the dash.
I made sure my battery cables all had a good connection.
Ideas????
Old 05-10-2011, 07:20 PM
JPP
JPP's Avatar
I have had two batteries die on me in my history and the symptoms sound the same. How old is your battery?
Old 05-10-2011, 08:08 PM
BlackCarrera
BlackCarrera's Avatar
Shot in the dark: Could it be the starter?.............
tonypai
tonypai's Avatar
I vote for a new battery.
Old 05-10-2011, 08:11 PM
MDamen
MDamen's Avatar
I would think that a bad battery would do more when you jumped it. I'm going for starter and/or starter solenoid.
Old 05-10-2011, 08:12 PM
shadow993
shadow993's Avatar
I'm thinking 4-5 years old.
But wouldnt jump starting work?
Old 05-10-2011, 08:14 PM
shadow993
shadow993's Avatar
I'm thinking starter solenoid. I will jack it and give the starter a few taps.
Can you push start the 993?
Old 05-10-2011, 08:17 PM
911Dave
911Dave's Avatar
Since the lights are on in the dash, it can't be the battery. You have juice, but none of it is getting to the starter. Probably the starter solenoid. I've had that happen in other cars with exactly the same symptoms.
Old 05-10-2011, 08:29 PM
BlackCarrera
Oh wow I'm not alone on this one! My fathers wrangler had the same issues, everything lights up, get a click, but nothing. Turns out it was the starter......
Old 05-10-2011, 08:31 PM
NC TRACKRAT
NC TRACKRAT's Avatar
When you press the remote, is the immobilizer light going off before you try to start it?
Old 05-10-2011, 08:44 PM
shadow993
shadow993's Avatar
Yes and the door lights flash as well.
In the past , if I didn't remove the key from the ignition in the off position... It would start without pushing the button no matter how long it was.
Old 05-10-2011, 08:47 PM
race911
race911's Avatar
Sure. A manual transmission one, anyway.
Old 05-10-2011, 09:00 PM
cabrio993
cabrio993's Avatar
Sure. I've push started mine a few times when I had a weak battery and a ground leak. Make sure you cycle the immobilizer first or it won't start. Put it in 3rd gear, wait until you reach 5-8 mph and pop the clutch. get ready to blip the accelerator as it attempts to start.
Sounds like a dead battery or a stuck solenoid.
Old 05-10-2011, 11:55 PM
shadow993
shadow993's Avatar
Thanks... I'm trying to get her home to check things out.
Old 05-11-2011, 12:33 AM
J.B.H.
J.B.H.'s Avatar
+1 starter solenoid
Quick Reply: Help! Help! My 993 left me stranded.
