Possible Lifter Failure - Couple of questions
Just fired up the engine for the first time after around 4 months of hibernation and there was one immediate and audible engine/exhaust "pop" then I noticed a distinct ticking noise at idle. I started the engine a second time and there was no pop but the ticking was as before. Total time for both runs was <60 secs. I assumed lifters requiring pressure but the pop got me worried. I then searched and read more about lifters. I went back out and left the engine running until warmed up. The ticking noise definitely quietened down to the point where any ticking now may or may not be classed as 'normal', I am unsure, probably because I am nervous and starting to imagine things.
1) Does the "pop" noise heard at startup point to something else or confirm anything?
2) As the sound has possibly 'gone' - does this point to simple lifter requiring pressure or indicate one is on the way out and should be changed immediately?
3) What are the possible repercussions for running the engine with a bad lifter - say if one decides to collapse completely while I am out and about driving? Will I get home without a tow? I could not figure this out from the search.
Few notes:
- Ticking noise was matched to revs.
- 15W-50 oil used. Ambient air temp today is around 60F.
- Car usually smokes for a minute after a cold start and long sit - today there was no more smoke than normal. No more smoke from one side than the other.
- 55K miles, 1000 to 1500 miles per year with annual oil/filters changes. Always driven until fully warm at least.
- No fault lights, all gauges look good, no other sounds I can detect
Any advice is greatly appreciated.
Few notes:
That is certainly a cold start, and many engines may be prone to some kind of weird ignition after so long sitting. You could've had a stuck injector or something dumping a lot of fuel to start with and a slow lifter.
RL Technical Advisor
Let me address your questions,.....
1) Nothing to worry about with that "pop" you heard. It may have been related to the sticking lifter or an artifact after a 4 month hibernation followed by an engine start. Without a lot more details, its difficult to say. Bottom line, its nothing to be concerned about unless its very loud.
2) Lifters make noise due to either wrong oil viscosity (not your problem) or seal failure which is a consequence of accumulated mileage and heat. The seals fail over time and allow the lifter to lose its charge of oil. Since the seals are not available anywhere in the world, Lord knows I've tried, one simply replaces the noisy ones as needed. If it pumped up after the engine was running for awhile, I would not worry about it, however its a data point for the future.
3) Personally speaking, I would not operate one of these engines with a failed lifter for very long due to excessive valve lash. The tip of the valve takes a real hammering when these things fail and the clearances open up far too much. Unless its an emergency and one cannot get a tow, I would have the car transported home or to a shop for replacement.
Hope this helps,
Thanks all for the prompt and detailed replies as usual. This community is great.
